Question about Cameras
I have a Kodak Easyshare V1003 which is about 9 months old. I just connected it to my PC with the included USB cable and it went dead after just a minute. Itried changing the battery and connecting it to the charger but none of the little LED's will come on. It acts like its been short circuited. Any ideas?
  • 3,083 Answers
You're right, it could be a shorted circuit, bent usb pins (rare), or a faulty usb cable, but most likely the battery terminals could be slightly dirty, or oxidized. In that case, you have to clean them with a qtip and alcohol. Also make sure your charger is putting out the voltage it should- it could be faulty.
Here is a web blog about cameras that won't power up, and it has some things to check for:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If nothing helps, the camera will require servicing. Get an estimate first, since the cost of repair can justify just going ahead and getting a new one.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 19, 2010
How do i transfer pictures to computer with usb
Plug your Razr into your computer via the included USB cable. A few seconds later pull down the notification bar at the top and you should see "USB Connection" and press on that. Select USB Mass Storage mode and press on OK. You should now see your Razr pop up as a removeable drive on your pc!
Sep 12, 2012 | Kodak EasyShare CX7430 Digital Camera
Cant transfer photos from camera connecting as instructed in book bot nothing happens
To transfer Pictures to PC only connect to PC using USB Cable.
If don`t work try the following
1.- Go to control panel -- Device manager
check if they are a yellow mark near the device
if have a yellow mark, select -- right click --Uninstall
2.- restart your PC and check if work
If trouble continue
1.- Try connect to other USB port
2.- Connect to another PC
3.- Try with other cable
You can buy USB Cable on
http://www.ebay.com/itm/USB-Cable-U-8-Kodak-Easyshare-C310-C330-C340-C360-/140526859630?pt=Camera_Cables_Cords&hash=item20b80db56e
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Kodak EasyShare C340 Digital Camera
I have a Kodak easyshare C613, when i plug the camera into the usb to get the pictures on the PC, it comes up with the error "the USB has malfunctioned and that the computer doesn't detect it" It has...
If this problem still is not fixed you can go online and purchace the DeOxit and add a drop onto your USB port and USB plug in hole - you may not be making good connections...($6 easy repair)
Oct 08, 2010 | Kodak EasyShare C613 Digital Camera
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
I have a kodak camera and want to download photos to computer
Try to install the Easyshare Software included in the package when you bought the camera, after that connect your camera the the USB port at the back of the computer using the USB 2.0 cable included also in the package.from there you can access the easyshare software and click on the transfer button on the software.
Oct 30, 2009 | Cameras
How to download pictures from a Kodak 10.3? What
you need kodak easyshare software and usb cable, when done installing the easyshare, connect the usb cable to your camera and to your pc after detecting the camera you can view the pictures from your camera and you can copy it to your pc
Aug 16, 2009 | Cameras
Do you have to uninstall old printer before installing new one
yes and make sure you diconect the usb cable first after you uninstall it re start your pc then install the other one do not connect usb cable until prompted during installation
Jul 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak AIO Easyshare 5300 scanning problem
Could be USB connection if you have another cable try it. Try connecting to different USB ports on your PC. If you have a Powerd USB hub lying around try connecting the printer to the PC through that.
Also try disconnecting all USB devices including the printer. Reboot your PC. Connect only the printer and try and scan.
Some times multiple USB devices dont work when they are both connected to the same PC.
Hope this helps!
SDtester
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak easyshare 5300 issue.
Call Kodak tech support and they will ship you a new printhead without any charge.
Jan 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Camera error #B03...oops, camera on before USB was connected
Kodak Technical Support Team. But I guess there is the possibillty you have barbied it.
Jun 23, 2007 | Kodak EasyShare DX6490 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
