Question about Frigidaire ATF6000ES Front Load Washer
Replace the belt on our Frididaire Gallerie Series 9/09. It now does not spin when there is a full or heavy load (towels). If it does the belt comes off. Is this a belt problem or the pulley? Thank you for your time. BL Welcome
    Novelist:
    Champion:
  • 266 Answers
Make sure your belt tensioner is mounted correctly. The belt should be tight enough that it takes a good 10 to 15 pounds of pressure (a good tug) to move it. But the belt should not deflect more than two inches either way. It really sounds like you tensioner.
Posted on Aug 19, 2010
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
The mashine doesn want to go on 1200rpm spin. It just spin at slowly. Model: Series 6 Varioperfect
Mine does this if the load is unbalanced, usually when it's got heavy items in it like bath towels, mats etc. I have to stop it, open the door, rearrange the items and start the spin again.
Sep 07, 2016 | Bosch Washing Machines
Zwp1121p Spinning but clothes still we5 through
Is the spin cycle reaching full spin speed or is it not spinning as fast as it should? If it isn't reaching full speed it could be caused by an uneven load (as this will stop some machines from spinning properly). Towels and items which get very heavy when wet can cause this.
Oct 27, 2013 | Zanussi Washing Machines
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Reduced spin, still soapy
please check if this type is using Belt to spin the drums, usually the belt is loose or damaged and need replacement.
To check the tension of the belt, Switch OFF or pull off the power cord for safety. Open the access cover , press the belts to check. Replace it if necessary
Idea:
If the belt slips the speed of the spinner is slow.
Dec 12, 2009 | Miele Washing Machines
Getting the machine to spin heavy load
you have a bad belt, your drain is too high
you can change the belt but you may need to get a high velocity pump if your drain tube is much higher than 1 foot above the machine
Oct 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Kennomre series 80
do not buy another machine, it can be repair . maybe the noise problem of your machine is the v-belt inside of it! or maybe the lack of lubrication. replace v-belt or lubricate the bearings and bushing.
Jun 18, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
