Question about Invicta Watches
Invicta Sea Thunder Chronograph resets to the 7 minute mark instead of the 12 o'clock position when using chronograph
  • jamespila_ho Aug 19, 2010
    I have a new Invicta Sea Thunder that does not reset at the 12 o'clock position when using the chronograph.
  • 11,800 Answers
The only thing that would cause that is an incorrect assembly of the clock - either the needle was incorrectly fitted to its shaft or the reset cog is not properly aligned with the mechanism. Since it's a brand new watch you should take it for servicing, there's nothing you can do about it without losing the warranty.
Posted on Aug 20, 2010
    Guru:
  • 1,051 Answers
Only thing I can suggest is you return it for a new watch. I had so many problems with my Invicta Pro Diver that I finaaly gave up and bought a Timex. Oh and the Timex keeps on tickin' for 1/3 the price.
Posted on Aug 19, 2010
  • Bob Korsu
    Bob Korsu Aug 19, 2010
    It's definitly a defect in the watch. Since it's new, you should have no problem getting a replacement or your money back.
  • Bob Korsu
    Bob Korsu Aug 26, 2010
    If you attempt to return the watch as defective and Invicta insists it's not under warranty start complaining and you'll get what you want.
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
May 03, 2015 | Invicta Watches
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
On a Invicta Men's Off-Shore Russian Diver Quartz Chronograph Silver-tone Watch, the big min hand does not stop at the 12 clock position but instead stops 2 mins before the 12. It stops on the 62 instead...
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Jan 12, 2010 | Invicta Off Shore Russian Diver Stainless...
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
Dec 17, 2009 | Police Watches
I can't figure out how to adjust the offset chronograph
This is to adjust the seconds hand or minutes hand for the chronograph. Pull the crown out either one click or two ... depending on the models. Squeeze and hold the top and bottom buttons at the same time (timer stop and reset buttons). Hold down together for 2+ seconds. The chronograph hands should reset by spinning around and stopping at 0. If the don't stop right at zero, you can now adjust where they stop. Leave the crown where it is in that same position out. Press the top chronograph button and hold it down for fast movement or short presses for fine movement to adjust til it stops at the top. This will adjust where the seconds hand stops. Then click the bottom chrono button once. Repeat what you did with the top chrono button and it should allow you to fine tune the position for the next dial, and so on. When you are done, press the crown back in all the way to the normal position.
May 21, 2009 | Invicta Dragon Lupah 2093 Wrist Watch
Have an Invicta Lefty Quartz Chronograph. The subdial that marks the minutes fails to reset to 60, though the large second-hand resets perfectly. Recently I bought another Lefty and had the same problem. I...
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
May 09, 2009 | Invicta Lefty Chronograph Watch with Band...
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Watches Logo
149 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
