Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
I have an XP2 in my 6 year old above ground spa. Recently the breaker keeps flipping after about 15 minutes of use and the pump motor is very warm. Is the pump done??
  • A Miller Aug 20, 2010
    Make sure there is no hair in the impeller. Replace the breaker (dont toss the old one. (Your filter is clean, right? -- What has happened with the pressture? Has it gone up the last year over previous years?)
  • bmijudie Aug 20, 2010
    I will check for hair or anything like that. As far as the pressure, I'm not quite sure what you mean but when the pump is running, it runs strong and perfectly.
  • 8,404 Answers
You have a gage on your filter? Anywhere on your system? I would suspect yout system should run at about 18 to 28 lbs PSIG when clean and go up about 10 lbs PSIG when it needs to be back washed.
Posted on Aug 21, 2010
Vs pump trips breaker. single stage 1 1/2 pump works fine, does not trip
is motor getting hot if so need new motor also check to see if wires on the back of the motor are loose or the wires to the breaker loose if they are ok you need a new pump motor or pump sometimes a whole pump is cheaper than fixing the old one
Jun 01, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
My robo kleen pool cleaned keeps flipping upside down. happens every time, i will watch it for a few minutes then come back later to check on it and it is upside down in the pool
check to see if the fan on top moves
if its stuck , then the motor is not pumping constant
and the pump may need some kind of lube
graphite perhaps
Sep 03, 2011 | Smartpool Dolphin Robo - Kleen Above...
Just installed a hayward super pump II 1.5 horse power. It keeps kicking the breaker out. It has a 15 amp breaker, can I just change breaker to 20 amp
could be you have a bad breaker. your old motor stresed the breaker now its weak. that motor draws 9.6 amps @ 230v i wold stay with the 15 amp, just get a new one.. jay the pool pump repair guy in longwood Florida
May 31, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a Sta-Rite pump and filter, several years old. I recently left town and returned to find the pump not working; however, it seems to turn off for a 15-20 minutes or longer, then turns on for about a...
This sounds like a heat sensor in the motor. If when it runs you can hold your hand on top of the motor the sensor may have gone bad. This is a quarter sized black disc about 1\2 inch thick in the back of the motor. Two or three wires and easy to replace. If the motor is getting hot then it's in the windings and your motor is short for this world.
Nov 29, 2010 | Sta Rite Above Ground 1 12 POOL PUMP 15 HP...
Polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Aug 24, 2009 | Polaris Pb4 - 60 Booster Pump
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
137 people viewed this question
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
Gene Haynes
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
