Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Clean unable I have a Brother printer mfc-240c type the digital screen says clean unable,,it just will not print or anything..I replaced the ink too..hmmm HELP e-mail me if you have a solution..szimm39_2000@yahoo.com
  • 2 more comments
  • hopesz43 May 03, 2008
  • Anonymous Sep 12, 2008
    My brother mfc-240 will not print and the screen doesn't say anything it always stays blank, whats wrong with it
  • Anonymous Mar 27, 2009
    My brother printer 5840cn unable to clean
  • Anonymous Mar 12, 2014
    iPad4does not recognise mfc-j47odw printer connected to same network
  • 487 Answers
Follow this LINK and rate me when you are done pls
Posted on May 03, 2008
Unable to get the printer to work it was saying i needed yellow ink
so I bought it, but still did not work, i thought it was bad i bought another one still does work I bought LC51Y my system MFC-240C
Posted on Jan 27, 2009
2 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
Cant print anything after replacing ink cartidges for brother 240c
If the printer has been sitting without use for a long time you may need a new printhead, if you just changed inks it could be just an air bubble in the ink tubes. If after several cleaning cycles you don't see any improvement, it's the printhead and not just a bubble.
Feb 22, 2010 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Clean unable 51
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
582 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
