Question about Home
How do you adjust the flow so it doesn't continue to run after flushing?
    Problem Solver:
  • 8 Answers
You have to adjust the float it is the thing inside of the tank it is either a ball on the end of a rod which you screw in to adjust or sometimes you have to bend it down a little. Or it is a float that goes straight up and down in that case there is a rod that runs down the length of the filler. Also check and make sure that the flapper in the tank is sealing all the way.
Posted on Aug 19, 2010
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
Water ridge toilet manual
Thus if the tank is continuing to drain down through the bowl into the sewer line, the rubber flapper is not seating properly with the flush. These become worn and torn and are easily replaced. Or, even with a new one installed, sometimes they are not adjusted properly to create the appropriate balance between play and pull. Play being the upward connection to the flush handle and pull being the downward draw with the gravity flow of the water. Too much play it won't actually flush or lift properly. Too much pull it does not seat tightly or won't lift up long enough to allow enough water to flow through to flush the toilet...as engineered by the geniuses who designed the toilet. A simple adjustment of the chain links attaching the flapper to the flush handle and perhaps a side to side turn of the cuff so the flapper is aligned to seat properly as it drops should be sufficient. And test, test, test, test, and test again until you're absolutely sure you've got it adjusted correctly. One or two flushes is not sufficient!
Dec 08, 2013 | Plumbing
Running Toilet
Sounds like your flush valve is shot. They are not that expensive and can be easily replaced.
Overtime the rubber in the flush valves break down and need to be replaced. Easier to replace the entire valve than fix the old one.
Semper Fi,
Z
Apr 30, 2017 | Home
Water flow from cistern does not shut off after the toilet in flushed
You need to get inside the cistern and see which type of shut off device you have. It will either be a long armed ball float or a short armed bobbin type. Ensure the float has not come away from the arm and that the adjustment is correct.
Mar 03, 2013 | Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
Toilet continuously runs
Check level in tank to make sure water is not running down over flow pipe. The float in tank should be cutting water level off about 5/8 inch before top of pipe. If this is it adjust the float or valve for proper level it shoul dhave amark on stand pipe also..
Also check flapper and make sure it is sealing off after you flush it can get caught on chain or what ever is connected to it from handle. If it is too long you can adjust it also.
May 14, 2010 | Home
Valve to stop water from running
IF YOU HAVE A FLUIDMASTER BALLCOCK,AND IF THE WATER IS CONTINUING TO RUN ,YOU NEED TO ADJUST THE WATER LEVEL,MOST OS THE TIME ALL YOU HAVE TO DO IS OPEN THE TANK LID AND ON THE LEFT SIDE YOU'LL SEE THE BALLCOCK,AT THE TOP IT MIGHT HAVE A BLACK PIECE THAT YOU CAN SLIDE UP AND DOWN TO ADJUST THE WATER LEVEL,OR SOME HAVE A PIECE THAT LOOKS LIKE YOU CAN USE A PHILLIPS HEADS SCREWDRIVER,ALL YOU HAVE TO DO IS TURN IT A HALF OF TURN EACH TIME UNTIL THE WATER STOPS GOING INTO THE OVERFLOW TUBE ,WHICH IS USUALLY LOCATED IN THE CENTER OF THE TANK AND IT WILLBE 1INCH ROUND ,IT ALSO WILL HAVE YOUR FLAPPER OR BALL CONNECTER TO IT.
Apr 07, 2010 | Toto Toilet Onepiece Ultramax ...
After flushing, water fills up tank and continues
Your problem is the water fill valve. Check this link.http://www.rd.com/17646/article17646.html
it's not the flapper or flush valve.
Mar 05, 2010 | Home
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
The gmax continues to run and won/t stop
if it worked fine and now it has stopped....then there is no adjustment that will fix it. If the fill valve is not shutting off you either need to replace the seal in the valve or get a new fill valve. If the water is leaking past the flapper you will need a new flapper.
Oct 20, 2009 | Toto Drake ADA Compliant Toilet with...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
