Question about Fuji FinePix S5200 / S5600 Digital Camera
Adding a telephoto lens
I have a S5200 and I wanted to use a telephoto lens for some bird pictures. When I put the telephoto lens on, the photo frame turns into a small circle? Any ideas??
    President:
  • 423 Answers
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
Posted on May 26, 2008
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
Dallas texas do you have a telephoto to fit a Canon EOS Rebel T3, 12.2 mp.?
Fixya does not sell any kind of equipment - contact your local dealer, or obtain via the Internet.
May 25, 2017 | Vivitar 100-400mm f/4.5-6.7 Series Lens
How to connect vivitar wide angle lens and telephoto to canon t2i
make sure the vivtar lens is "58mm" diameter (shoutstate this near the fron of the vivtar lens) then it should be a question of screwing the lens on top of the other lens. not the best way of getting wide angle shots as the 18-55 is pretty soft in focusing already and adding another inferior lens will make it look poor. if you don't want to buy a lens i would suggest investing in a tripod and take multiple shots with the 18-55 and stitch them together with a photo editing tool like photoshop
Dec 30, 2010 | Canon EOS 550D Rebel T2i Digital Camera
My nikon d40 wont take a photo with the standard lens unless I switch it to manual but when I put the telephoto lens on it works in both auto and manual. How do I get my standard lens to work in auto (the...
Sorry to hear about your lens. If you are able to take pictures with a telephoto and any other AF-S lens, then it means that your problem lies with the standard lens. With standard, I assume you mean the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning, I had the same thing happen to my 50mm 1.4 lens. The kit lens is under 5 years warranty in the US, provided you are the original purchaser/owner of the camera kit.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 15, 2010 | Nikon D40x Digital Camera
Can you tell me the best choice in a telephoto for NiKon N5005 ca
try looking for a cheap 70-300mm AF-D i'm not sure it the AF-G version (no aperture ring, control via body) will work with your cam.
Dec 22, 2009 | Nikon N5005 35mm SLR Camera
I am having trouble photographing birds. Do I use the telephoto lens or the wide angle lens? I also have a macro lens for my Canon EOS 400D SLR Also what settings do I take them at. I have a tripod but the...
Use the telephoto lens.. wide angle will tend to distort the image and provide too much detail( distraction) around the object of interest. Bird pictures become more interesting when they are mainly of the bird. So when you look through the lens, zoom up to the bird to the point where you have it nicely framed with none of its parts outside of the frame.
Capture the whole image.
Wide angle lens is mainly used for scenery or where you want to take a group photo or panorama.
Please rate my help++++Thanks for using FIXYA
Nov 29, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Flashless photograghy
If you set the camera to P (program) the flash will not pop up automatically but the camera will still control the shutter speed and aperature settings automatically. Also with the lens you are using you should probably have a tripod which will help you hold the camera more steady.
Jun 10, 2008 | Canon EOS 40D Digital Camera
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
104 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
