Question about Yard Machines Garden
31 cc 17"weed wacker everytime i hit the trigger it dies out like its under load put new spark plug in it still does it i cant rev it up at all or it dies out
  • 24 Answers
It appears to be a fuel problem. Could be the fuel filter is off letting the line **** in air instead of gas. Could have a cracked line or primer bulb letting in excess air. or it could be a dirty carb.
Posted on Aug 19, 2010
I have a Ryobi 430 4 stroke weed wacker try to start this morning seems like it was frozen up took spark plug out pull the string free flow rotates easy put spark plug back in very hard to start fraid I'm...
Paul you might want to replace the spark plug, make sure the gap on the plug is correct, make sure there is oil in the machine, some have a safety switch when the oil is low. If you cant buy a new spark plug you can sand off the tip that is probably black and replace it in the machine
Nov 28, 2014 | Garden
No spark
To test the spark you will need a spark plug tester. Put one end of the tester on the spark plug and the other in the plug wire. Pull the cord and see if fire is there. If not you will need to replace the coil.
Jun 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Help my weed wacker string
Pull the spark plug out and try pulling it over if still won't move might have seized the motor possible not enough oil in gas You can try if not to much damage done pour some kerosene or stove oil down spark plug hole let sit over night try again
Jun 08, 2013 | Garden
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
2 cycle 31 cc 15" model 705r curved shaft trimmer plus click link weed wacker ..seems to flood,fuel drips from air intake ,after carb adjustments still will not start cant seem to regulate fuel ,checked...
Check the metering diaphram and check valve in the carby.The valve might be leakin and the diaphrm might be hard. do a google on the make of the carby as these are fitted with a few makes manly Zamer but. DONT use compressed air to clean or automotive type carby cleaner all will kill the valve and its not replacable..
Jul 01, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hve a Craftsman Weed Wacker 24 cc Need to find out how to put new nilon cord in the weed wacker its been some time since i've done this.
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
Jul 08, 2009 | Craftsman Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Garden Logo
79 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
