Question about AT&T Plug & Share 6500G (650530003387) Wireless Adapter
I just installed the at&t wireless pci adapter 6500g in my new HP desktop with Windows 7 and now I can't get wifi, the device was working fine in my 5 year old HP desktop from before with Windows XP
Is WIFI installed and ready to go withthis OS?
The OS itself does not contain wifi. Wifi is hardware that is installed in the device. AS far as the OS is concerned, yes the OS does support the wifi networking protocols. You MAY have to load the wifi adapter driver(s) for you device if Windows does not have a native one that is compatible, however. You can determine whether or not the driver is installed by going to the DEVICE MANAGER and looking at NETWORK ADAPTERS. If there is no wireless adapter present or there is an exclamation mark alongside the adapter, then you need to load the driver to get wifi functionality within the OS.
Feb 15, 2016 | Microsoft Windows 7 Home Premium 64BIT...
HP Pavilion dv9205us wifi issues
Is your version of Windows 7 32 or 64bit? Open the Network and Sharing Center, select Change Adapter settings, is the wireless adapter listed? Is the Wireless Adapter in the Device Manager under Network Adapters? Have you done ALL your Windows and HP updates? Usually Windows 7 will apply the generic driver to the devices. Do you see any UNKNOWN DEVICES in Device Manager? You can find drivers here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3340198 Some times you can use Vista drivers by changing compatibility. Post your findings and which version, 32 or 64 bit.
May 22, 2013 | HP Pavilion Computers & Internet
Is this system wifi compatible
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. Most new HP (Hewlett-Packard) Pavilion notebook computers as of August 2010 include an internal wireless networking adapter, used to connect to a wireless network or router. Once connected to a router, the computer can connect to the Internet or other computers on the same network. If the wireless networking adapter is not allowing the computer to connect to a router, there are several steps that can be used to remedy the problem. Ensure that the wireless network adapter is turned on. Most HP Pavilion notebook computers have a switch that allows you to turn off the wireless adapter. The switch typically is located on the side of the computer or on the front. Ensure that the router and modem are plugged in and functioning. Ensure that the lights are illuminated on each device. Attempt to connect wirelessly using another computer, if possible, to test whether the connection problem is with the router or modem. Unplug the router and modem. Leave the power off for approximately 30 to 60 seconds, then turn them on again. Update the wireless network adapter driver using the computer's "Device Manager." To access the Device Manager, right-click on "Computer" or "My Computer," depending on the version of Windows, and click "Device Manager" from the left-side bar, or from the tab labeled "Hardware." Once in the Device Manager, expand the section labeled "Networking Devices" and right-click on the wireless network adapter. Click "Update driver software" to begin searching for an update. If an update is found, follow the onscreen instructions to install the update. Reinstall the wireless networking adapter if updating the driver does not remedy the problem. To reinstall the wireless adapter driver, right-click on it from the Device Manager and select "Uninstall." Once the device is removed from the computer, restart the computer. Once Windows loads, it will automatically detect and reinstall the driver. Run the Windows 7 Diagnostic Tool (if the computer uses the Windows 7 operating system) to diagnose any networking issues the operating system may be able to correct. To access the Windows 7 Diagnostic Tool, open the "Start" menu and type "Network" into the search field. Click "Network and Sharing Center" and then select "Diagnose and repair" from the left-side bar. The Windows 7 Diagnostic Tool will automatically run and will attempt to repair and establish the wireless connection. Attempt to manually connect to the wireless network. Open the "Network and Sharing Center" and click "Setup a new connection or network." Enter the network name, security type and network key into the text boxes and click "Next." If successful, click "Use the existing network" and then click "Connect." The network name, security type and network key can be obtained from the network administrator or by logging into the router. For help logging into the router, consult the instructions included with the router. Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure key scroll http://support.microsoft.com/
Feb 09, 2013 | HP Pavilion Media Center m8530f...
Greetings, I am a technician. However, I ran into a confusing issue with my wi-fi. My Encore enlwi-g v2 PCI wireless adapter worked fine on my Windows 7 64-bit system until I bought a new Smilodon case...
Mike, your problem is so clear and crisp... Thank you for the excellent documentation...
Here is the solution...
The wireless PCI card should be detected by any PCI slots, doesnt matter whatever may be the chipset made off...
The Light in the adapter is "OFF", says there is no power supply to the adapter and that is the reason the Wireless card is not detected...
unplug the adapter from the board and clean the PCI slot on board with a soft brush(the Pins in the PCI slot may get in contact with each other if u use any hard materials to clean)...
On the PCI wireless card clean the metallic contact surface (the place where the pci slot comes in contact with) using an ERASER and clean the dusts left by the eraser properly...
Now connect it back and check if the light is getting LIT up on the card...
Then you can also check under device manager either in Network adapters or under other devices...
Sincerely, Manny...
Dec 09, 2010 | Encore (ENLWI-G) (ENLWIG) 802.11g/b...
PC Windows xp wont detect networks: PCI 802.11 WN5301A
hi, try to press the register/discover button on your router so as to make your computer able to detect the network or get the latest driver update for your wifi dongle/card
Jan 13, 2010 | Computers & Internet
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
AT&T Plug & Share 6500G (650530003387) Wireless Adapter Logo
260 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
