Question about Paintball Tippmann U.S Army Alpha Tactical Mod Kit
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
    Novelist:
    Scholar:
  • 111 Answers
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
  • peanut227170
    peanut227170 Apr 15, 2012
    I'm Having the same problem my gun ate up my whole tank, I had only fired around 600 shots with my 20oz tank. Im not sure what the problem is, should I lower the velocity?
Hi, I am trying to remove a brand new CO2 cartridge I just put in a new Gamo PT-85 Blowback pellet hand gun. As I'm unscrewing it, gas is leaking out. HELP.
Hello K Brink,
Kind of like deja vous (all over again )...
Pretty sure: This is the same Question I answered
yesterday (no / yes? ).
There is no going back... Once the CO2 cartridge is
pierced... there is no way to salvage the cylinder
until it is FULLY expended...
If you unscrew the chamber the CO2 will ALL be released.
Just ONE word... If your cylinders are depleted... ALWAYS
check that the SEALING O-ring stays with the hand-gun.
Just make sure yur SEALING RING is still in the "gun"
and NOT STUCK to the ... co2 CARTRIDGE.
I am just saying...
((been there... Done that))...
Carnac the Magnificent
Nov 29, 2017 | Gamo Optics
Hello K Brink,
I am just saying...
Gun was working fine, now will not fire even with new co2 cartridge, any suggestions
It is possible the 'new' CO2 cartridge is defective.
If the gun was working fine BEFORE you installed the new CO2 cartridge, try a different cartridge.
Maybe the seal wasn't pearced on the new cartridge. Also, a blockage would also prevent the gun from firing. Check the gas pathways for a blockage.
Aug 13, 2015 | Miscellaneous
How do i reassemble my xbg air ******?
Really? It's been a year and no one answered his question? What kind of BS is this? This is a common CO2 gun that is sold in many retail stores, and even a quick Google search brings up nothing than this.
Guess I'm stuck figuring it out myself.
Aug 28, 2014 | Umarex XBG CO2 Semi Auto Pistol .177...
What is a blowback airsoft gun?
Blowback Airsoft Guns are Airsoft weapons that seem much the same as true firearms, since genuine firearms, well some, are secured in a Blowback layer of paint or something to that effect.
The entire slide on the gun with re-cock itself consequently after every shot then generally in the wake of shooting the complete cut after the last shot the slide stays open. The main issue with these airsoft guns is they will consume through your gas. CO2 or green gas both can have blowback.
Jan 14, 2013 | Sport & Outdoor - Others
New Project Salvo. Second day tried to use it fires like it is on full auto for a second or two. Wont shoot as semi auto . It drains the CO2 quickly and sometimes the trigger gets stuck on full auto. ...
It's vary common for places to not fill Co2 tanks correctly and it sounds like this is your problem. Try having your tank filled in a different store, If this doesn't work you should exchange the gun at the store you bought it or call Tippmann, they have a excellent 2 year warranty.
Sep 09, 2011 | Tippmann US Army Project Salvo Sniper...
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
Apr 30, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
I have a walther bb gun, need to find parts..
HI. YOUR BB GUN HAS NO FIRING PIN,,IT USES A SMALL TYPE OF RELEASE TO LET THE SPRING GO IF THAT IS THE TYPE OF BB GUN YOU HAVE. IF ITS THE (CO2) TYPE IT RUNS A LITTLE DIFFERENT BUT NO FIRING PIN. I HOPE THIS HELPS. JIMBO
Aug 15, 2009 | Sport & Outdoor - Others
Paintball Tippmann U.S Army Alpha Tactical Mod Kit Logo
215 people viewed this question
Top Paintball Sport & Outdoor - Others Experts
Bill Eager
Are you a Paintball Sport and Outdoor - Other Expert? Answer questions, earn points and help others
