I have a WINIA WSH 188AL split unit. It will come on with the remote, give a green Cooling indicator light for 10 seconds then go to the heat indicator and a time delay indicator and the green cool light goes out and it never cools. What could be the problem?? and where can I get a manual with some wiring prints in it??
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
bobotfel
  • 236 Answers
SOURCE: No cooling, suction pressure reads vacuum Split AC
The unit is restricted, reprocess the system, flush and vacuum it thoroughly.
Posted on Mar 24, 2008
  • 400 Answers
SOURCE: mistral mss20 split a/c only cooling somtimes 4 about 10 m then
Sounds like your unit may be a bit short of refrigerant and the compressor is therefore cutting out on low pressure.
Posted on Mar 05, 2009
  • 25 Answers
SOURCE: Samsung split AC is not cooling
Most probable short of refrigerant. Would have to have atech put guages on it and check.
Posted on Mar 11, 2010
What does a flashing light mean?
a flashing light could mean any number of things. normal operation, number of communicating components, a minor alert such as a filter change or major alarm like pressure error or control board problems. first we would need the number of flashes and /or sequence of multiple flashes AND the model number of your "split heat pump!"
Jan 13, 2018 | Heating & Cooling
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Ac not cooling
Try turning the main isolator off for 10 minutes to reset the system. If it doesn't clear the error, count how many times the light flashes which will give you the error code.
Oct 09, 2017 | Fujitsu Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
