Toshiba SD-K860SU DVD player not loading disk...
I purchased the Toshiba SD-K860SU DVD player at Costco months ago, I have not played used it much at all, so when I tried to play a DVD recently I was surprised that it did not play, I had a "load disk" problem., the screen came up but it never loaded the DVD, I tried several of my DVD's which I had played on the system before. I have tried everything related to this problem that is stated in the "before you call service" section in the manual on pg 48. Now I have called technical support and they could not help, now I have a seldom used product that does not work. I am checking the purchase date with Costco since I do not have the receipt anymore, I'm sure it is just past the one year warranty, so you won't back your product. It's very disturbing that a product that was very seldom used is already not functioning. I am an engineer and if I ever put out a product like that I would be embarrassed. Toshiba SD-K860SU DVD player S/N: 1208001104
  • 1 more comment
  • Anonymous Oct 26, 2008
    identical problem
  • Anonymous Dec 13, 2008
    I have the same problem. My was working fine until I left a DVD loaded in the player without playing the DVD. When I came back I found I could not load the DVD.
    I also tried the different book troubleshooting steps to no avail. I have concluded that it is a software or memory problem. Some electronics can be reset by merely upluging it. Not this DVD player.
    I have not yet been able to get it to work.
  • ghazanfar1 Jan 18, 2009
    I have the exact same DVD player and exact same problem. Bought it from Costco some time back > 2 years. Has used it of and on but last month it won't work. I opened up the chassis and found that the mechanical assembly that moves the head up and down was stuck. After I freed it up, the player worked for a while (3 DVD's) but got stuck again on 4th. Since then, I can get it to work but after a couple of DVD's its stuck again and I have to free the mech again. Bad design?
SOURCE: Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Posted on Nov 16, 2007
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
SOURCE: Teac CD X-9 player
Try to sleep more and have a good time.
Posted on Jun 14, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
Posted on Jan 18, 2009
Erratic operation of DVD players after a few months of non-use
what you should do is to clean the OPTICAL LENS directly with a dry Q-tip , could be that it collected some dust and thats why its playing erratically, give it a try , AJ
May 29, 2009 | Toshiba SD-1800 DVD Player
yes that is very possible. cleaning the lens of the dvd player should happen atleast once a month. it can also be that the lens itself is scratched or the lase does not reach the disk tracks due to dust or bad handling
Mar 29, 2009 | Toshiba SD-5000
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Not playing DVD's
have you asked for profesinl help or take it apart to fix the problem
Dec 18, 2007 | Toshiba SD-P1400 Portable DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
346 people viewed this question
Top Televison & Video Experts
