The belt on my washer has come off and I cannot put it back on as the belt is not loose enough how do I put it on?
    Novelist:
    Champion:
  • 266 Answers
The electric motor bolts have to be loosened. After you loosen them and put the belt on I always tighten the bolts snug and then use a hammer to tighten the belt by tapping on the motor base. Or you can use a pry bar old tire tool ect but its easier to tap it tight. Make sure you unplug your washer first. I hope this helps.
Posted on Aug 19, 2010
How to replace belt on maytag washer mav6451aww
not sure on model but if its like any other washer look to see where the belt runs around should run around motor and a big wheel looking thing that joins to tub on the moter there should be three nuts and bolts 2 to keep it aginst bulk of washer an 1 that should be able to ajust losen this one move the motor so there is enough room to put new belt on make sure that the belt goes in the runners of the motor and drum part use a large screw driver to lever the motor so belt goes tight and still with the tension on belt fasten the nut up harder to describe than actually do hope this helps ivan uk
Aug 25, 2012 | Maytag Washing Machines
Washer not working
The spinner's belt might be loose or broken, that's why it doesn't spin... Open the back part and you'll see inside the belt and the motor that makes the noise.
post me results...
Feb 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer drum belt worn out....does that damage other parts?
First thing I would do is replace the belt as the old one may have streched
Apr 01, 2017 | Maytag PAV2300 Top Load Washer
Why the fan is not working , the fan not move
1.Check to see if the washer is overloaded. Modern washing machines have automatic shut-off devices for out-of-balance loads. Try removing some of the clothes out of the washer and restart it. Check to make sure the lid closes properly and that the lid switch clicks when the lid is closed. If the lid switch does not click, then the switch may need to be replaced or the lid may be bent. If the washing machine still does not spin, go to Step 2. Make sure the water is draining properly. If the water does not drain out, then it could cause the washing machine not to spin. Check all the drain hoses for any clogs or kinks. This is easily done by disconnecting the drain hoses and doing a visual check for clogs or kinks
3.Check to see if any belts have came off or are loose. Unplug the washer and pull it away from the wall. Use the screwdrivers to remove the back panel. Visually check for any broken or loose belts. Replace any loose or broken belts.
4. While the back panel is off, visually check for any loose or missing bolts on the motor or drum. If any are missing or loose, tighten them and replace the ones that are missing.
5. If everything has checked out to this point, then the water level switch could be bad or the water level hose could be clogged. Remove the front panel of the washer and locate the clear tube going from the tub to the water level switch. If lint or debris has gotten into the water level hose, then the washer may not spin fast. Clean the debris from the hose by blowing on the hose or tapping it on the side. To check the water level switch, go to the back of the washer and locate the back end of the water level hose. Use the voltmeter to check to see if the water level switch is getting any power.
6.If the washing machine still doesn't spin fast enough or doesn't spin at all, then it is time to call in a professional washing machine repairman.
  • 1
    Checkto see if the washer is overloaded. Modern washing machines haveautomatic shut-off devices for out-of-balance loads. Try removing someof the clothes out of the washer and restart it. Check to make sure thelid closes properly and that the lid switch clicks when the lid isclosed. If the lid switch does not click, then the switch may need tobe replaced or the lid may be bent. If the washing machine still doesnot spin, go to Step 2.
  • 2
    Makesure the water is draining properly. If the water does not drain out,then it could cause the washing machine not to spin. Check all thedrain hoses for any clogs or kinks. This is easily done bydisconnecting the drain hoses and doing a visual check for clogs orkinks
  • 3
    Checkto see if any belts have came off or are loose. Unplug the washer andpull it away from the wall. Use the screwdrivers to remove the backpanel. Visually check for any broken or loose belts. Replace any looseor broken belts.
  • 4
    Whilethe back panel is off, visually check for any loose or missing bolts onthe motor or drum. If any are missing or loose, tighten them andreplace the ones that are missing.
  • 5
    Ifeverything has checked out to this point, then the water level switchcould be bad or the water level hose could be clogged. Remove the frontpanel of the washer and locate the clear tube going from the tub to thewater level switch. If lint or debris has gotten into the water levelhose, then the washer may not spin fast. Clean the debris from the hoseby blowing on the hose or tapping it on the side. To check the waterlevel switch, go to the back of the washer and locate the back end ofthe water level hose. Use the voltmeter to check to see if the waterlevel switch is getting any power.
  • 6
    Ifthe washing machine still doesn't spin fast enough or doesn't spin atall, then it is time to call in a professional washing machinerepairman.
  • Read more: How to Repair a Washing Machine That is Not Spinning Fast Enough ' eHow.com http://www.ehow.com/how_5025687_repair-not-spinning-fast-enough.html#ixzz1CKKbvlyA
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
    Jan 28, 2011 | Magic Chef CAV2000 Top Load Washer
    Hotpoint aquarius tumbler not turning belt was off so put it back on and still tumbler not turnig altho bottom motor is working
    the belt didn't get put on the idler pulley and does not have enough tension to turn drum, recheck belt routing
    Nov 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
    Our belt came off but we don't know how to put it back on
    1. Look and find the pulley tensioner of your
    washer, and loosen it up. This is a bolt holding
    the motor base,and allow the base to move and
    loosen the belt or tighten it.
    2. When it is loose, you just put the belt back on the
    big pulley track and then, on the small pulley.
    3. Full the tensioner back in place to tighten the belt.
    Just follow this instruction, and solve your problem.
    Sep 28, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
    My washer doesn't wring the clothes fully.
    It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
    Sep 04, 2009 | Maytag Performa PAV2200
    The washer is making loud squealing noises. I took the front panel off to take a close look and notice the motor is able to be moved back and forth. Is this normal? I tried tightening the mounts and it...
    Set the drive belt over the drum, loosen the motor slightly, because I think you are cross treading the belt. check the belt before fitting to see if there is any damage to the belt. With your hand put the belt on to the drum, back onto the motor, turn very slowly until the belt finds it's own parallel (the grooves line up), then tighten the motor exactly where it is in place. If there is NO damage to the belt, set the machine onto a fast spin, empty. That should tell you it's a belt problem. But you may have to spend 10 bucks on a new belt. Cheaper than a new machine. Hope all goes go well for you, let me know! Dave
    Jul 15, 2009 | Maytag MAT13MN Top Load Washer
    MY ADMIRAL WASHER WONT SPIN FAST ENOUGH..IT DOES SPIN BUT WHEN IT STOPS THE CLOTHES ARE STILL DRIPPING WET
    Sounds like a whirlpool or inglis type belt drive with a loose belt or bad basketdrive[clutch].
    Could be the set screw backed out on the basket, thats a pretty common problem.
    I'd need a model number to know who made it though.
    May 19, 2009 | Admiral AW22 Top Load Washer
    Belt comes off
    maybe not, is the belt condition good, if so check for any wobble on the pulley, you may have worn drum bearings, this will cause the large pulley to wobble and throw the belt when it spins, also you can check the belt for being tight, it should be fairly tight but not tight enough to cause it to snap, if loose there should be adjustment at the motor end on the motor housing, all of this is assuming this is not a brand new belt, if so have you bought the right one?
    Sep 27, 2007 | Kenmore 43042 Front Load Washer
    Washing Machines Logo
    44 people viewed this question
    Top Washing Machines Experts
