Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
System freeze ok... this could be because i have an adapter that converts it from firewire to USB, anyway... I click on the driver, either the one that came with it or the newer one from the behringer website and it it asks me to plug in the device, i plug it in and my system freezes, mouse doesnt move, nothing... then as soon as i unplug it its back to normal and screen suddenly shows what i did when it froze (e.g if i move my mouse to the left when its frozen the mouse is suddenly to the left) whats going on with that!?
Which driver are you using now that you have 'converted' firewire to USB? The USB driver or the Firewire driver. I suspect none would work, as the Firewire driver os looking on the FW bus/layer, and the USB there. The devices may not communicate at all in the same way to either interface.
Posted on Jun 28, 2008
My j5 create VGA adapter will not connect
So the major limitation on today's computers is the Max power available to the USB bus on the motherboard. Last I checked this was 1,000 mA. This unit draws 500 mA. Depending on how many other things are connected via USB to the laptop, youmay not have enough power to drive the dongle. Best solution for this, even if it isn't the problem, is to get a powered USB hub. That relieves the need for the OS to do calculations on which devices get USB power at start up.
Try this if you can.
Mar 05, 2014 | J5 Create USB 2.0 VGA Display Adapter...
I bought a used sky caddie from a friend. I can not connect the skycaddie to my computer as the plug will not match.
Hi there.
SkyCaddie usually comes with a USB or Firewire Connector or Cable. If you computer does not come with a FIREWIRE port, you can buy a Firewire to USB adapter.
Which model do you have anyway?
Thanks!
Feb 07, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
I am unable to connect my handycam with my pc via usb please send me proper sugeestions
The USB cable connection ability in Windows for video transfer was discontinued after Windows XP. Anyway, the quality of the video through the USB cable is terrible.
You'll have to buy and use a DV to Firewire cable to retrieve the video off of the camera. If you don't have a Firewire 800 adapter on your computer, you'll have to buy an adapter add-on for your desktop computer. If your laptop doesn't have a Firewire port, then you're out of luck -- buy a new laptop with one.
See pages 43 on in the user manual for more information.
Dec 22, 2010 | Sony DCR-HC54E Mini DV Camcorder
Firewire/USB
Hi beccarkt,
Although not sold at Best Buy™, there are available adapters/cables to make this transfer possible. I recommend using a search engine to find "firewire to usb." Hopefully this will give you the results you need.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 11, 2008 | LaCie (300740) 160 GB Hard Drive
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
OR TRY THIS
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Apr 21, 2008 | Apple iPod MA446LL/A MP3 Player
Serial adapter need driver for xp
no need to install serial adapter it is built in for windows xp. but if you want to connect other devices using serial connection you need to install the driver e.g printer, modem etc.
Apr 17, 2008 | Computers & Internet
No firewire 800 or 400 functions in Leopard for SIIG FireWire 800 + Hi-Speed USB Combo PCI Adapter
Unistall and reinstall through control panel. use the drivers it came with. Make sure the drivers are for ur OS. If not, check with manufacturer for proper drivers.
Mar 14, 2008 | Computers & Internet
Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Sep 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
93 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
