Question about Kitchen Ranges
Maytag gas super capacity plus stove error code F9
    Scholar:
  • 58 Answers
F9 relates to a bad door latch
either you need to reconnect a rod
or you have a bad latch(sometimes solenoid asembly depends on age)
Posted on May 02, 2008
F9 error after power glitch
F9 is a door latch problem. its saying it can not read or detect if door is open. repair latch. good-day ! Unlock door and inspect the switches or clock assembly.
Nov 27, 2011 | Maytag MER5770 Electric Kitchen Range
Maytag, advanced cooking system , super capacity, error code f9
A model number would help, but an F-9 code is usually followed by a 1, 2 or 3.
F-9-1 is the board is not seeing the door lock
F-9-2 is the board not seeing the door unlock
F-9-3 is the board seeing both inputs and not knowing the condition of the door lock.
The problem is like caused by a failed switch in the door lock mechanism. This normally requires the replacement of the door lock assembly.
Nov 22, 2010 | Maytag Kitchen Ranges
I have a Maytag super capacity range and I am getting an F9 error message on the display. I can't find the model number and it is not where maytay said it would be on the range (according to the site)
The F9 fault code means door latch problem. Check door latch hardware. Here is a list of the Code Description for your unit. Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. DON'T FORGET TO RATE THIS POST!!
Sep 18, 2010 | Maytag Kitchen Ranges
How do I get rid of stains from the surface of my Maytag Gas Range top(Advanced cooking system Super capacity plus) I always ensure that all spills are promptly cleaned off the enamel stove top, but the...
Use DeBruce Polish, we use it on all of our stainless steel AND ceramic cook tops- we also use Debruce Polish on all of our windows. We used Debruce to remove permanant marker from an enameled surface. This stuff is great! We find them at debrucepolish.com. Debruce is non-toxic and odorless- you will love it.
Oct 20, 2009 | Maytag Kitchen Ranges
F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Apr 09, 2009 | Kitchen Ranges
STOVE CODE FLASHING
f9 depicts a door lock error
3 specifies the latch lock lower sensor
Mar 01, 2009 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Whirlpool Super Capacity 465 gas stove
Find the paper in the envelope on the back of the stove. (Behind the console.) This will tell you what those fault codes mean. Be sure to replace the paper. If it is needed again, that is where a technician will look for it.
Mar 31, 2008 | Kitchen Ranges
Kitchen Ranges Logo
926 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
