Question about Garden
Cub cadet pto clearance model 141731100 - Garden
  • 69 Answers
SOURCE: I can not get my mower deck to turn when I pull
Your switch could be bad, or the voltage needed to turn on the PTO may not be up to par, or you may have a safety switch that won't let you start the PTO. I'd start with the safety switches.
Posted on May 11, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
How to replace drive belt on cub cadet 1050
Fairly easy to replace once the deck and the electric PTO are removed just make mental notes or rough of the belt path before removing the old belt. One thought if I remember correctly this uses 7/16" belt and a 1/2" width will not work due to the tight clearance at the engine pulley so stick with OEM belt.
Oct 14, 2014 | Cub Cadet Garden
Cub Cadet,model 2135. Is there a relay betwee switch and electric pto?
a short on the hydro wire have to find chase the wires from pto back if you dont find it take it in because if you dont you will burn up the stater
Sep 19, 2014 | Cub Cadet Garden
Need to know the pitch 8m for pto clutch
if your talking about the bolt that goes through the center of the pulley your model number shows it as a 3/8-24x1.75 long. everything I see on the pto is standard not metric. this link will show you the pto breakdown for your model
Parts and Diagrams for Cub Cadet 144 653 100
May 16, 2014 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Pto not engage when hot
Is the pto electric? if so it may hav excessive clearance between the clutches because of wear which would cause it not to be able to engage when hot
Oct 31, 2013 | Cub Cadet Garden
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
