Question about Daewoo DWC-056CL Air Conditioner
I have a daewood nano silver dwc 055rl. I can't change the temp setting. It doesn't cool.
  • 2 more comments
  • suereal Aug 19, 2010
    Mine is a window unit (DWC055rl). Thank you for your help but I need window unit help. Please try again.
    I have a Daewoo Nano Silver WINDOW A/C #DWC055RL. It doesn't cool the room. I am unable to change the temperature . Please help.
    If this is common with this AC, where does that leave me? Is the unit caput? Can I fix it ?This is a fairly new unit and was not used much at all. How can I contact the company if I can't fix it?
    Even though I found out that my AC unit is not worth fixing, it's good to get closure on the matter. Willard answered all my questions and concerns. He was very professional & responded to each of my replies in a very timely manner.
    Thank you!
    Sergeant:
  • 252 Answers
Your clock board is bad. This happens when moisture from the outside gets into the electronic circuit board. This is common with your model of AC.
Posted on Aug 19, 2010
  • 6 more comments
  • Willard Broughton Aug 19, 2010
    Yes there is your local tech or a AC repairmen can order this clock board for like $30.00. One question is it still under warranty?
    No, it's not under warranty. And it makes me mad b/c it was stored indoors in winter.And not used much. I want to contact Daewood. Do you know how to do that? By the time I order the part , then pay a service person, it might just not be worth it. What do you think,WIllard?
    Let me get that information for you. How much did you pay for your unit.
    877-893-7823 I think it would be better to get a new unit
    I don't really remember; not an exorbitant amount. I really feel that the company ought to honor this defect. If you can get me the customer service info, I would greatly appreciate it. I tried online, but was not successful.
    And thank you for your help.
  • 503 Answers
A central air conditioner that runs but doesn't cool may just need to be cleaned. Plan to do this on a relatively warm day. First look for your owner's manual and, if you can find it, follow its instructions. If you can't find it, request one from the manufacturer (see Resources).
To clean the filter, remove it from the furnace or air handler (it?s usually located inside or very near the air inlet side). Replace a disposable filter or clean a reusable filter according to the manufacturer?s directions.
1) Before you begin, check the thermostat to make sure it is set to "cool" rather than "heat." Then turn off the power to the unit; there is normally a shut-off or disconnect panel on the house wall next to the outdoor compressor. Otherwise, shut off the air conditioner's 240-volt circuit at the main electrical panel.
2) Rake leaves and debris away from the outdoor condenser.
3) Remove any protective grille or cover from the condenser's fins.
4) Use a soft brush to clean dirt and debris from the fins, then vacuum them with a brush attachment (be careful not to bend or damage them). If you accidentally bend fins, you can buy a comb made for straightening them at an appliance parts store.
5) Unscrew and lift the top grille off the unit, if possible. If the fan is attached to the grille, be careful not to pull any wires loose.
6) From inside the unit, hose out the fins (protect the wiring and motor with plastic). If your owner's manual calls for lubricating the motor, do that now--don't over-lubricate.
7) Then reassemble the unit.
8) To test it, turn the power on and set the thermostat to turn the unit on. Let it run for a few minutes, then feel the two pipes that connect to the condenser unit (slide any insulation back). One should feel warm, the other cool. Otherwise, call an air conditioning technician--the refrigerant may need to be recharged.
NOTE: Avoid straining an air conditioner's compressor by waiting at least five minutes between turning it off at the thermostat and turning it back on.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
How to Remove the grill on my deawoo Dwc-055rl air conditioner
at the lower outer edges of the grill you will find indents
place your fingers at these points and pull out and up
the grill will lock up while you attend to the filters
closing is just pressing down on the grill until is clicks into lace
Jul 18, 2016 | Heating & Cooling
How to trouble shoot Daewood air conduitioner
clean intake filter. if already cleaned, have system recharged or replace unit. air comes into the unit through the front and out the top vents,, if block or restricted it wont cool. if the air flow is good its how cold the evaporator is. so either freon level is low or compressor is bad.
May 15, 2014 | Newegg Daewoo Dwc0520fcl 5000 Cooling...
Plants are drooping and leaves starting to die
hps is better for growing, mh is to promote reproduction....
try shorter light cycles
Jan 21, 2014 | MB Quart DWC 254 Car Subwoofer
1. What is the BTU rating of the DWC-0520RLE 2. Where is the room temp sensor located
The style of keeping the model number changes co to co. But you can read from your unit BTU. 12,000 BTU is equa to 1 TR. The room temp should be located near by return air grill.
Dec 02, 2010 | Heating & Cooling
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
I have a daewoo dwc 055rl air conditioner and i need a new remote. do you know where i need to go to replace it?
Hello, I have a brand new AC of that model, in the box with remote that I'd be happy to sell. That way you could have two AC units and a remote. I'm in Laguna Beach, CA.
Thank you,
Russell
rboston@gmail.com
Feb 12, 2010 | Daewoo Heating & Cooling
I need to replace the plug on my Daewoo DWC-055RL Air C
You should be able to get this item at most hardware stores they are very generic. just take or draw a picture of the plug end there are only about 3 styles
Dec 23, 2008 | Daewoo DWC-056CL Air Conditioner
Nano i pod has locked silver ipod nano
i forgot my ipod code
help me
May 26, 2008 | Apple iPod nano
Daewoo DWC-056CL Air Conditioner Logo
749 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
