Question about Samsung SGH-X510 Cellular Phone
I NEED THE DEFAULT PASSWORD TO RESET SETTINGS
3 Suggested Answers
Sub Zero
  • 55 Answers
SOURCE: I ACCIDENTALLY RESET MY SETTINGS
Good day the default password is 00000000 (8 zero's) Hope you get it right
Posted on Sep 11, 2007
SOURCE: What is the default password
default password:00000000
Posted on Feb 15, 2011
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
How to reset the default user name and password?
if you've forgotten it, you can reset the default settings of the router. At the back of the router, you'll find a push button usually labeled Reset which you can push for about 15 to 20 seconds to get the router back to its default configuration. then you can set it up again and set your password if needed. the default password is normally password
Jan 26, 2011 | D-Link Wireless N 150 Home Router 4Port...
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
Will resetting the factory default settings allow me to change the password w/o knowing the password? Why would you need to reset factory default settings anyways? Also, where can I get a PSP 2000 manual?
the manual can be found here. for all sony game systems.
http://us.playstation.com/support/manuals/index.htm
you would need to reset to factory default setting for the exact problem you are having -- forgetting the password. so your question is "YES".
The Restore Default Settings feature will erase any previously saved settings and restore all of the settings to the default.
  1. From the XMB™ home menu, go to icn_settings.gif (Settings) > icn_systmsetting.gif (System Settings) > [Restore Default Settings].
  2. The message "Do you want to restore the default settings?" should appear. Select "Yes" and press the icn_btnx_color.gif button.
  3. You will then see a message, "All settings will be returned to default settings. Are you sure you want to continue?" Select "Yes" and press the icn_btnx_color.gif button.
  4. All settings are now restored and the system password is reset to "0000".
  5. Press the icn_btnx_color.gif button to restart the system.
  6. Re-enter system settings as appropriate.
this is the site i got the info from
http://us.playstation.com/support/answer/index.htm?a_id=538
May 20, 2010 | Sony PlayStation Portable (PSP) Console
What is the default password for lemon mobile?
lemon duo it717
reset factory settings
Apr 06, 2010 | Cell Phones
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
Samsung SGH a727 forgot password to turn on phone
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Sep 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
I can not remember the password to get in my router
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
I forgot my password
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Lost the password for my wireless router, need help to reset.
If you forgot the password of your router, you can reset it by pressing the reset button of the router for 20 seconds while the power is ON and after that power the router off for 5 seconds and then the router will be back already to its default settings with default password...
Dec 28, 2008 | Arris WR850G Router (DHWR850G)
Samsung SGH-X510 Cellular Phone Logo
125 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
