Question about Bernina Artista 170
I have version 1 of the Bernina Artista Software. My old laptop had a parallel port. Laptop crashed. Bought a new laptop with no parallel port. I have order a cable with a usb connector and parellel port connector. I hope this will work. Any experience with this situation and if it does indeed work? Hope someone can help. Also would like to upgrade software from version 1 to version 3. Any pitfalls in doing this?
  • 109 Answers
I had this same problem and when I tried to hook it up I got the error message "port com # in use." I remember this was an easy to solve problem a long time ago but I can't remember what I did to fix it. Someone from the computer store is going to try and fix it but I don't know "when!" Since I got a cheap hard drive put in my old computer, I'm going to reinstall it there if I can and just use it for that. If you're going to upgrade it make sure you can get the version 1 in your computer first and upgrade after it's up and working.
Posted on Aug 23, 2010
I have Bernina Artista embroidery software version 3. I have a laptop with windows xp2 on it. I have downloaded all the updates but It still won't recognize the security dongle. What can I do. The...
Not sure, but I believe version 5 works on XP.
Perhaps this will help:
https://www.bernina.com/en-US/Support-US/Software/BERNINA-Software-Compatibility/Bernina-Software-Compatibility
Feb 20, 2018 | Bernina Artista 170
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Jun 23, 2010 | Bernina Artista 180
I need to convert my parellel port dongle to USB
I have the same problem...V3 software. have not heard of an adapter. The software wouldn't work with Windows XP or Vista anyway. I upgraded to Editor plus V5 but have kept my old Designer plus on an ancient laptop so I can transfer old patterns. You will also find that your new laptop doesn't have a serial port to accomodate the old cable to bernina 180. Unfortunately it's always the case with updating a PC. Everything else has to follow! My advice, get hold of an old laptop:)
Jun 16, 2009 | Bernina Artista 180
New computer won't work with Artista software
You need a new security code. When we changed computers we worked with the dealer on where to send the form requesting Access code. You can find the form under Help on the far right of your menu bar. It's the last item called Access Code Order Form. They emaild it back to us with the code we needed along with the install instructions. The dealer should also be able to assist you with your laptop issue, although you may only be able to use the software on 1 PC or laptop as you are probably licensed for 1 copy, and they us the dongle to validate the software and the machine combination.
Best of luck.
Nov 20, 2008 | Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Can't connect my Bernina 170 Embroidery unit to my computer
I just bought a new laptop and upgraded to V.6. Since I have always used a magic box I didn't know how to attach my bernina 170 directly to the laptop. My bernina dealer said that I would first need a serial to usb adapter since my machine is old enough that it doesn't have a usb port on it. Make sure it doesn't have the screws on the serial part because they will not allow you to attach it to the machine. He also said that I may have to make a new com port as most pc laptops only show 4. I did a search of the computer and found how to make a new com port. A little more fiddleing around with the laptop and cables and restarting both then it somehow recognized that I had made a new com port. Voila. It now works. (I am a Mac person). Hope this helps. margaret
Jan 04, 2008 | Bernina Artista 170
Artista v3.0 security dongle
I am using a docking station for my laptop that has a serial port.
Dec 26, 2007 | Bernina Artista 170
Sewing Machines Logo
78 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
