Question about Star Kitchen Ranges
Running machine starts then after so long stops and comes up with a fault el stl
I have a hyundai accent 1.3 1999 model, it jst stop while the engen was running, went to mechanic to check the wiring, he recomended I buy new distributor, I bought it as well as new coil nd plug cable but...
check that the timing belt is not broken
It would have been the first thing a good mechanic would have done
the second thing would have been to run the fault codes to get the fix right.
Mar 24, 2015 | 1999 Hyundai Accent
Trac Star 4500 trouble Code EL STL
The error code by definition is listed in section 3 of the service manual.
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20TR4500.pdf
Dec 08, 2013 | Startrac Fitness Products Star Trac 4500...
How to set time and date for mercury 130w etr
Prodeuce a z report 1st.
-Press vdmode untill displays 4...........
BLACK MACHINE>Press total.Press sh button then total (displays date).Press - *minus button.Key in current date.eg 180515 ddmmyy.Press stl twice.Proceed with time,press + *plus button.key in current time.eg1610.Press stl.Switch off machine.
Aug 18, 2013 | Boating
1985 el camino it starts but wont stay running
You need to check for fault codes, to do that go here.
Jul 17, 2013 | 1985 Chevrolet El Camino
Message ELSTL what does it mean
This means the elevation has stalled. Please see the EL STL Flow Chart in the service manual starting on page 68.
Aug 11, 2012 | Startrac Fitness Products Star Trac 4500...
Trac star 4500 have a message el stl what does mean
I'm a technician for StarTrac. Visit my website to learn more about me and my company. Contact me directly and I'll give you what ever free advice I can offer. I'd love to help if you don't mind passing on the good word.
Brian Clark (or Christine Reid)
No Assembly Required Fitness Equipment Repair
www.wefixfitnessequipment.com
Oct 20, 2010 | Startrac Fitness Products Star Trac 4500...
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Printed manual?
hi you can download to your pc, i had one that i did as my daughter in loss, hopes this helps, linda
Sep 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Sep 06, 2007 | Washing Machines
Kitchen Ranges Logo
21 people viewed this question
Top Star Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Star Kitchen Range Expert? Answer questions, earn points and help others
