Question about Whirlpool Refrigerators
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze. Refrigerator is eight years old. Please advise. Thank you. mspel@optonline.net
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 19, 2010
How to tell the model number
Is it coming out under the vegetable drawer? We just had a problem with water dripping down into the freezer. Check the drain at the lower back left of the refrigerator, above the bottom shelf to see if it is plugged. Water will be pooling there. If it is, use a turkey baster and warm water to flush it out.
I never found the serial number for our unit but used the model number from the manual.
Nov 23, 2013 | Liebherr KIKNV3056 Bottom Freezer...
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
195 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
