Question about Microsoft Windows XP Professional for PC
Xp how get start taskbar from top to bottom? - Microsoft Windows XP Professional for PC
  • 149 Answers
Hi
What could be simpler?? Just drag and drop the taskbar down like window
Posted on Aug 19, 2010
  • 1 more comment
  • depetersen Aug 20, 2010
    yes. simple. but tried many times and not work yet. thanks anyway, dp
  • Yuriy
    Yuriy Aug 20, 2010
    Right click on the taskbar then
    pull-down menu uncheck "Lock the Taskbar" and then drag down
  • depetersen Aug 24, 2010
    Thanks a lot for the second response. Turns out I was even more inept than we thought. I had done both of the things you suggested. The reason dragging didn't work was that I thought it should move down as I dragged it, but it didn't move until it reached the bottom. So, thanks again. Don Petersen
Start is at top
First see if your taskbar is locked. Right-click on an empty area of the taskbar, for example right next to (but not on) the Start button. You should see a menu with "Lock the Taskbar" near the bottom. If there is a checkmark next to it, your taskbar is locked and can't be moved. Click on "Lock the Taskbar" to remove the checkmark. If it isn't checked, leave it alone. Release the right-click.
Next left-click on an empty area and you can drag the taskbar to any side of your display you want - top, bottom, left or right. If you have a multi-display setup you can even drag it onto a different monitor screen.
Once you have the taskbar where you want it, right-click and check "Lock the Taskbar" so it doesn't accidentally get dragged someplace else.
Aug 11, 2014 | Microsoft Windows 7 Ultimate for PC
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
Lost start button and icons on my toshiba lap top
Do you mean the taskbar along the bottom of the screen?
If you move your cursor to the bottom of the screen the taskbar should appear. Right click anywhere on the taskbar and click properties. In the properties window, on the taskbar tab, uncheck 'auto hide taskbar'.
Mar 29, 2012 | Toshiba Satellite L655S5158 156Inch Laptop
Cant get rid of classic theme and taskbar in xp
right click in the taskbar you will see toolbar options
whether you are in top toolbar or bottom toolbar this will variate
at the bottom of the top toolbar right ckick from drop down list will be a customise option
hope this helps
Jan 24, 2012 | Epson C823633 Network Adapter
THE TASK BAR APPEARS AT THE TOP OF THE WINDOW
First, make sure the taskbar is not locked. Right click the taskbar and make sure the is no check mark beside 'Lock the taskbar".
Now, point your cursor just beside the START button (outside the START orb and on the task bar), click and hold and now you can move it to the bottom of the window.
Jul 13, 2010 | Dell Computers & Internet
My taskbar is not showing after u start the computer
When you say "after u start the computer" you mean before you log in? The taskbar never shows up until you're logged in, so that's the way it's supposed to work.
If you've logged in and you still can't see the taskbar, it's possible that you've configured the taskbar to "auto-hide." To see if that's what's happening, move the mouse all the way to the bottom of the screen, and the taskbar should pop into view. Unless you've moved the taskbar to the top or side - check by moving the mouse all the way to each edge of the screen until you see the taskbar.
Once you see the taskbar, you can right-click either on the "Start" button or on the clock at the opposite end of the taskbar, and select "Properties" from the menu to turn off auto-hide (if you want to - some people like it once they're used to it). If you want to turn it off, pick the "Taskbar" tab on the Properties dialog, and uncheck the "auto-hide the taskbar" checkbox. Then click OK, and the taskbar should stay visible.
Hope this helps.
Oct 06, 2009 | Microsoft Windows XP Home Edition
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
My whole taskbar is not visible
If you move the mouse pointer to the very bottom of the screen, the taskbar should pop up as it does when you press the Windows Button, but without Start. If you want to keep it up, right click on the taskbar and select "Properties" In the new window, "Unselect" "Autohide" and the taskbar will stay up.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Windows XP taskbar has "relocated itself"
Right-click the taskbar and ensure it's not locked..
Then just click on the taskbar and drag it to the bottom of the screen..
But i didn't understood the iconzied windows thing.. omg
PS: Please rate this solution
Mar 11, 2009 | IBM Lenovo ThinkPad T60
My taskbar has moved.
Mar 11, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional for PC Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
