Air con unit is on but compressor wot work - Heating & Cooling
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 19, 2010
Why does the compressor for the air conditioner not go on even though the circulating fan does.
What sort of air con is it? If its a split or ducted with a separate outdoor unit, does the outdoor fan start ?
Mar 18, 2015 | Heating & Cooling
How can we tell if we need a air con unit.There is a loud grinding sound coming from the front passenger side of the engine.
In some cases, the clutch on the compressor can go bad, or the compressor can stall and burn out the clutch or the belt that runs the compressor can burn up. There is a lot more to this problem than replacing the compressor so it would be rather expensive to have it serviced and it is too hard to do yourself without a lot of tools and training.
Aug 09, 2014 | 1999 Honda Odyssey
Outside compressor turned it self on and pipes are covered in ice, without the Inside air con coming on. I have not had the air con running for two days. to turn off the compressor I had to turn it off at...
Hey mate,
Have you cleaned the filters on the indoor unit. Check the evaporator(in door unit) coils for build up and debris. Check the out door unit coil for leaves and debris. IF they all are clear. Could be low on refrigerant, faulty metering device or a blockage in the refrigeration system.
Jan 06, 2013 | Heating & Cooling
Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Mar 27, 2012 | 2003 Audi A6
We have a 2007 CX7 and the air conditioning is not working well on either recirc or outside air in low ambient temps. When idling at the lights the air con becomes worse. There is no belt sqeal, and I dont...
When you have a moment pop the bonnet and look for the air con compressor run by a automotive belt on the side of the engine. Get the engine running at idle and then get someone else to turn the air con on whilst you watch the compressor. As the system is turned on the compressor clutch should engage and the unit should start turning, if this isn't happening there isn't enough pressure in the system (leak or just low on pressure) Get to your local air con guy and they will pressure test for leaks. Air con system is run on pressure, so that is really the issue you need to rectify
Note:- Manufacturers put the air con rad infront of the engine rad so stones get to that first, check the condition of the front rad through your bumper
Feb 19, 2011 | 2007 Mazda CX-7 Grand Touring
My air con is not working.it has gas in the system,relay is ok,air con switch is ok but the air con compressor does not turn on when air con is on.when you direct the compressor or brigde the relay,the...
You may have freon in system but compressor won't engage unless it's full under pressure. By jumping the the relay you're doing damage to compressor by running on low pressure. Have system evacuated and recharged to proper amount of freon - usually 4 lbs of freon
Jan 30, 2011 | 1994 Hyundai Excel
1999 grand jeep cherokee limited air con prob water coming out vent behind driver seat and water drops noted under glove box front passenger side ???? what to do air con recently regased works well but...
You have a leak in your air conditioning compressor Your system works on the reheat principle All air passing through the system is cooled and reheated before it enters the cabin this sould be dehumidified air but it passes through the heater core and sence the air is not dehumidified you are getting condansation as the air flows the heater core that is heated by the engine heat and the water is from condencation because of the leak in the ac compressor The unit is a press fit in the center of it and fials unfortinatly a lot with this disgien of compressor
Nov 26, 2010 | 1999 Jeep Grand Cherokee
I have a air con in the bedroom and it kept coming
it can be due to compressor not working or Refrigerant leakage
Mar 04, 2010 | Heating & Cooling
LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Mar 31, 2009 | LG Heating & Cooling
LG AIR CONDITIONER NOISE
What kind of air conditioner is this? A window unit or a split?
Sep 19, 2008 | LG Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
