What can we do if the video tapes being played have Snow and try to play the video player with cleaner, we have to turn on and off. It automatically lose control.
  • 734 Answers
Head cleaner tape for vcr just dry scrubs the rotating head for a short time. Remove it to check playback performance, to see if head is clean. If good, then record some program and see if snow is gone. some tape maybe recorded when the head is dirty, lots of snow. Some tape may have improvement if tape is run over knife edge to hone the magnetic surface, US patent granted years ago to reduce computer tape noise.
Posted on Aug 19, 2010
The VCR is completely off track.. Does anybody has any solutions?
If by "off track" you mean it cannot track an image on the tape, it may just need cleaning. The heads, head drums, guides, and rollers in the playback mechanism require cleaning on a regular basis and, if they are not cleaned regularly, oxide particles and dirt accumulate to the point that the VCR is no longer able to play tapes.
Although automatic head cleaners are available, they're more for maintenance, and if it isn't playing tapes anymore it's beyond that. I would recommend taking the VCR to a repair shop for cleaning... shouldn't cost very much, and it should solve your problem. (Let's hope that the heads aren't worn down... bit more of an issue.... but try the cleaning first.)
Once you have the unit running again, buy an automatic cleaning tape and use it every few plays.
May 21, 2015 | Panasonic DMR-E75V DVD Player/VCR
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
When playing a tape back in the camcorder i can hear audio but there is no picture only snow
The audio and video are read by separate heads. In your case, the video heads need to be cleaned. If you have a "newer" camera, you will need a head cleaner in VHS-C format. An older one can use a standard VCR head cleaner. If you can not locate one, a professional will need to dis-assemble the camcorder to get at the heads to clean them.
One other trick you can try is to take a blank tape and FF it to the middle, start it in play mode and do a reverse scan for a few minutes. That may clean the heads as well.
Dan
Dec 15, 2009 | JVC Video Cameras
Sound but only snow for picture
make a deep clean ur video head with a video head cleaner or with a soft cloth with some mild soap.
May 06, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Movie tapes have snow but not home video tapes can i fix it my self
I assume you have had this player a while and I assume that all the programs that work without snow are ones that you recorded using that VCR to do it. Right?
If so, it is a compatibility issue where the last time you had it fixed, the repair guy did not check for VCR to VCR compatibility. I had a shop for 15 years and this is common.
Do you have a Tracking control? try adjusting that. It is either a physical control or part of the menu, depending on that specific model.
Last...last is to open the unit and you must be very very careful. Put in a tape that is from another player that plays snow and identify the shinny rotating head if you can physically see it. It sits at an angle and the RCA is typically in the back middle, about an inch in a half in diameter. While playing press your finger very very lightly in the middle of the shinny exposed video tape for like 4-10 seconds and maybe the snow will go away.
Your video head may be worn or dirty. Do not attempt to clean the heads the are verrrry delicate.
3. Try finding an old VCR cleaning tape. It does the same thing as your finger.
E
Mar 01, 2009 | RCA VR349 VHS VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Sylvania DV220SL8 DVD Player/VCR Combo
You could try cleanining it first that would be a simple solution
Go buy a video head tape or due it yourself radio shack has video head cleaner. Remove cover unplug clead small silver audio head on right side. good luck
doctor video
May 17, 2008 | Sylvania DV220SL8 DVD Player/VCR
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
