Question about Sharp CD-PC3500 CD Shelf System
Protect mode can't use any buttons need the senquence in order to unlock the system
    Problem Solver:
  • 17 Answers
Most sharp reset by pressing the power button to enter the power stand-by-mode while pressing down the volume down button ,press the power button un-til ALL CLEAR appears...hope this helps...yammandan
Posted on Aug 19, 2010
Alarm in my 2002 gmc Sonoma goes off when I open the door with the key. Lost remote. Can I disable the alarm without messing other things up?
Door Key Switch
The BCM monitors the door key switches in order to disarm the CTD system. When the lock cylinder turns in order to unlock the door, the switch grounds the disarm input to the BCM.
The key lock input to the BCM is probably missing , BCM doesn't see it . So it think's your breaking into the vehicle. Did you try the passenger door to see if it will disable the alarm .
The BCM - body control module ! Electronic -computer !
Content Theft Deterrent (CTD) Does Not Disarm with Key Lock
The factory service repair manual has a 23 step diagnostic procedure . An you would need a factory scan tool to find the correct fix.
Turn ON the ignition with the engine OFF.
With a scan tool, observe the door key switch parameter in the Body Control Module (BCM) security data list.
Does the scan tool display INACTIVE?
Locking the Vehicle Without Arming the System
Use one of the following procedures in order to lock the vehicle without arming the system:
• Procedure A -- Lock the vehicle using the manual door lock knobs. Close all the doors.
• Procedure B -- Close all the doors. Use the key or the power door lock switch in order to lock the door. The doors must be closed prior to locking the doors for this procedure.
Disarming the System
In the arm initiated mode, the following conditions are true:
• The security telltale is ON.
• The doors are open.
In order to disarm a system in the arm initiated mode, perform one of the following procedures:
• Press the power door lock switch to the UNLOCK position.
• Press the door unlock button on the key fob.
In order to disarm a system in the arm delay or the armed mode, perform one of the following procedures:
• Use the key in order to unlock one of the doors.
Deactivating the Alarm
In the alarm mode, the following conditions are true:
• The horns sound intermittently.
• The headlights and the park lamps are flashing.
In order to deactivate a system in the alarm mode, perform one of the following procedures:
• If the vehicle control module (VCM)/powertrain control module (PCM) receives a valid Passlock™ ignition key rotation.
Nov 29, 2017 | GMC Sonoma Cars & Trucks
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
How to get my remote key fob on my 1997 lasabure to work
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the DOOR unlock switch.
While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation
Jul 31, 2014 | Buick LeSabre Cars & Trucks
How do i turn off "File Protect" and be able to delete again. It won't let me delete pictures and there is a little animated figure on the print that says digital camera out to the side with...
You have accidentally selected lock option.You need to select unlock option for the same. Press the menu button and then press right/left button to select the protect menu. Then you need to select unlock and that would turn off file protect.
Kindly accept the solution so that i could get the credit for my time.
Thanks and Regards
taran_2005
Jul 11, 2011 | Vivitar Cameras
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
mode.
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
How do I unlock protected pictures?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Update! I just tried this on a Samsung S630 - hopefully the process will be similar for you (the camera certainly looks the same). You have to be in playback mode. Press the menu button, and go to Playback. Move to 'Protect' and select that mode. You can navigate through the pictures, and on mine, T(elephoto) locks it, and W(ide) unlocks it. In any case, the on-screen instructions should tell you what key it is.
If this doesn't work for you, don't mark it unhelpful (yet) but say so, and I'll find a user manual for your exact model.
Jan 31, 2011 | Samsung S85 Digital Camera
Need to reprogram new keyless entry fob.Thanks.
You may program up to 4 transmitters, using following procedure:
Transmitter Programming Procedure (No Tools Required)
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Turn the ignition switch to the RUN position in order to exit the key-less entry transmitter mode.
Jul 22, 2009 | 2001 GMC Jimmy
Program fob
Instructions to program a keyless entry remote for a Chevy Silverado. They also work on 2003, 2004 and 2006 Suburbans.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the DOOR unlock switch.
  4. While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to four transmitters.
  8. Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
  9. Operate the transmitter functions in order to verify correct system operation
Apr 19, 2009 | 1999 Chevrolet Silverado 1500
How can i program the key less?
  9. Operate the transmitter functions in order to verify correct system operation.
Dec 03, 2008 | 1999 Chevrolet Astro
RCA 27' tru flat sdtv- power light comes on- no display,no sound.
How do you unlock your TV from Protective Mode? There is a certain code that you need in order to unlock the Television. The technicians are saying that it went into Protective Mode, when it umplugged all by itself. I need the code so I can watch my TV again.
Nov 23, 2008 | RCA TruFlat 27F520T 27" TV
Sharp CD-PC3500 CD Shelf System Logo
373 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
