Question about Toshiba (P000352160) Computer Speakers
I have the volume to my speakers at full volume and I can't hear the sound very well. Any suggeations?
  • 64 Answers
Could this be because the speakers are under your laptop? Propping it up might help. Or alternatively check the volume control. There is seperate volume for main volume and wav volume. Raise them both. -Ravi Shanghavi
Posted on Aug 19, 2010
How can I reset the volume control? All of a sudden, I can barely hear with the volume set at max.
You do not mention the type of Motorola radio so this answer will be general. You may have a problem with your volume potentiometer, Receive (Rx) sensitivity, or a speaker problem.
The volume pot on a 2-way radio is a common failure item, and will after repeated use possibly fail, or get dead spots. Try backing off your volume to 75% and see if it is louder at this setting. If so, you have a bad volume pot.
Rx sensitivity can be caused by various internal problems with the radio,and some models are more prone to this than others. Operating your radio at full volume most of the time can bring this issue to the forefront. (Tip: Try running your radios at 80-90% volume vs. full volume to alleviate this problem.) If this is your issue, your effected radios are in need of repair. Most repair facilities (including ours) can correct Rx sensitivity in most models during a repair.
Speaker problems: If you work in an environment where dirt, debris or metal shavings can get inside the speaker, your speaker may fail over time. Or if you run your radio at full volume the majority of the time it can cause your speaker to fail.
Best regards.
Oct 13, 2014 | Motorola Walkie Talkies 2-Way Radio
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
I have a set of SUN-115H speakers that has a volume problem. When testing with DXDIAG, you can hear the sound but it is very faint even with the volume knob turned to full. Any ideas? ? ?
Is the power to the speakers correct? Since these are computer speakers,have you checked that the volume on the computer is turned up all the way? Have you tried the speakers on another computer or portable radio of something?
May 06, 2011 | Sun -115H Computer Speakers
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
Sound plays but very low volume even if plug to speakers and amplifier and full volume, you hardly hear anything. Hoping for a solution. Regards,
right click on the speaker icon in the system tray on the bottom right side of the screen and then click to open the volume mixer then make the speaker sound level to 100 %.
or go to the control panel from there click on the sound or speaker icon to open it after that go to properties and then make the volume level to 100%.
This should help to fix the problem.
Mar 23, 2010 | Computers & Internet
Just got this cliq yesterday can't hear without using speakerphone with incoming or outgoing call they can hear me but I can't hear them untill I put it on speaker please help
Dear ,first check ur volume after connecting a call ,when call connects then check that ur speaker volume is full.if ur spaker volume is full and u can not hear anything so that's ur speaker problem.So u have to claim ur warranty or go to a certified mobile fone repairer to change ur speaker and it'll not be expensive.take care
Jan 29, 2010 | Motorola Mobility CLIQ Cell Phone
Volume on radio at full volume can barely hear it
sounds like you have a bad solider on the board.
Jan 16, 2010 | Cobra 29 LTD CB Radio
No sound from phone
your speaker may not work properly you need to change the speaker
Oct 02, 2009 | Nokia 6131 Cellular Phone
Tin like sound from small speakers only. No sound
switch on your speaker set in full volume unplug it from computer touch the plug , as you touch you can hear a sound ( loud hum sound) if the speaker is working. If okay then check the right jack, plug it into green color jack. you can try if your computer is okay use a headphone plug it into the jack in PC , if the computer is okay you may hear the sound.
Jul 01, 2009 | Dell OPTIPLEX 960S Desktop Computer
173 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
