Computer dosen't recognize Mymusix Mp3 So i can't download music to it.
If the device has a reset button you may be able to use that to clear your settings back to factory defaults, check with your user manual, but sometimes that helps. It shouldn't erase what is already on it, but if you can't download music to it, it shouldn't be a problem if it does. Occasionally in the settings there is a different protocol, which means the language in which it talks to the computer and you may be able to switch that protocol to talk to the computer as well. Additionally, check in My Computer if you have Windows, a lot of times it's just listed as an extra storage device in there. If you want more specific information please post what type of computer you have, what version of Windows, and what exactly you're doing when you hook up the MP3 player and what/if the computer does.
Posted on May 02, 2008
2 Suggested Answers
SOURCE: mymusix (PD 135-02) 1GB MP3 player files not recognized by my computer
usually Windows media player works. if you burn cds and copy thos songs or copy downloaded song files to the audio player in the media player and then syncronize, it should work.
i'm currently having problems in it for the first time after about a year and half but it usually always works.
Posted on Nov 28, 2007
How do i take music off my mp3 player
Remove battery in MP3 unit. Plug in computer, when drive opens showing files hit CTL-A. All files in MP3 player will highlight. Hit DELETE. Your MP3 player should be empty & ready to load with your files.
Oct 15, 2009 | MyMusix PD-6070 MP3 Player
Sharper image mp3wma player not seen
it wont show up and it says that there is no music when you turn it on and on the computer it says there is music on it
Aug 12, 2008 | MyMusix PD-6030 MP3 Player
My mp3 player wont turn on
This might be a tricky one to solve - may take more than one method.
Start by resetting the player. Then replugging it into the computer.
If it still fails:
Uninstall the PD-6030 via device manager. The PD-6030 needs to plugged in to do this. Go to Start, Control Panel and select 'Performance an Maintenance'. Then Select 'System'. Then select the 'Hardware Tab' and select 'Device Manager'. Then find a device called 'Portable Devices' or 'Windows Portable Device'. Then select the + sign next to the device and right click the 'Audio Player'. Select 'Uninstall'. Click 'OK' when it asks you if it is OK to uninstall. Then select 'Action' at the top of the Window and select 'Scan for hardware changes'. Then once it re-installs the driver, see it operates
correctly. Also, performing a firmware recovery procedure can work to make your computer recognize the PD-6030. Please follow the set of instructions titled, "Q: How to recover my player's firmware?".
The firmware upgrade can be found at www.mymusix.com
-Tha Mp3 Doctor
Jun 13, 2008 | MyMusix PD-6030 MP3 Player
Delete music from pd-6070
The MyMusix device software is buggy and prone to break downs from time to time. Reformatting the device usually fixes these problems. The best way to reformat is to use the manufactures firmware update process.
Go to the MyMusix.com website and download and install the firmware upgrade for the PD-6070 player using the download drop-down menu.
Back up all of the songs on your player to your computer hard drive.
Carefully read (or better yet print for future reference) the PD-6070 FAQ instructions for running the firmware upgrade, especially the drop down to select the US version of the firmware.
Run the firmware upgrade. It will reformat your device and restore it to it's original capacity.
May 06, 2008 | MyMusix PD-6070 MP3 Player
MY MP3 IS SAYING ERROR REFORMAT INTENAL MEDIA AS FAT16.
you neeed to go to my computer and right click on the Mp3 and click format, if you don't your Mp3 will just stop working that is what happend to me
Apr 04, 2008 | MyMusix PD-6070 MP3 Player
Will not download to "Music"--only to "Voice"
With your mp3player attached, open my computer look for "MyMusix pd.."-something like that and then open "Music".
Now that you have that window open,
open the folder where you have your music in [My Music]
Now simply drag the songs to the music file on your mp3 player.
Hope that solved it, please rate.
Jan 01, 2008 | MyMusix PD-6070 MP3 Player
How do I remove music from MyMusix PD-6070?
plug the player to pc. open up the player driver from my computer and then just delete the songs you don't want.
Dec 29, 2007 | MyMusix PD-6070 MP3 Player
Mymusix (PD 135-02) 1GB MP3 player files not recognized by my computer
MyMusix MP3 Player PD-6110 doesn't show up on my computer. I'm using Windows 98SE and downloaded the driver I needed but I still can't find this device.
Nov 22, 2007 | MyMusix PD-135-02 MP3 Player
HOW DO I DELETE THE SONGS ON MY MP3 PLAYER
You can generally connect the device to the computer and see the information under My Computer>Device Name. Then you can manually add or delete music from the device. Best of Luck.
Sep 12, 2007 | MyMusix MX-F01 MP3 Player
79 people viewed this question
 Grubhead
Grubhead
