Dishwashers Logo
Posted on Aug 19, 2010
Dish wash stuck on DEMO , can not programme - no information in manual
Anonymous
Level 1:
Champion:
  • Contributor 245 Answers
  • Posted on Aug 19, 2010
Anonymous
Contributor
Level 1:
Champion:
Answers
245
Questions
0
Helped
33155
Points
5
Try killing power to your dishwasher and then turning back on.
2answers
How to switch of demo mode in miele washing machine
I need the model number to be able to help you.
How do I run the first cleaning programme for the new machine.. I can see the button to press but what washing cycle I put. I cannot have "wash cycle number auto clean" as the booklet says.
First, I'm not a Ariston Representative.
* Check your warranty. Call for service.
*** The following is for information only.***
* Page 4 of instructions;
" The washing machine has a auto clean programme for its internal parts that must be run with no load in the drum"
* your basically run the machine empty (no clothing)
* There is no specific "Auto cleaning cycle" button.
* Instructions; https://aristonbrand.com/media/RSF-82-B-AUS_GB.pdf
* The "Cleaning action" (page 6) is just an indicator to tell you what part of the cycle your in.
* Demo of features (Official); https://www.youtube.com/watch?v=NF_ZNDir_38
* Specs; http://aristonbrand.com/inventory/rsf-82-b-aus/
* Brochure; http://aristonbrand.com/media/RSF82BAUS.pdf
* Product review; https://www.productreview.com.au/c/front-loading-washing-machines/m/ariston.html
Aloha, ukeboy57
PS; for some reason Hotpoint keeps getting matched with Ariston;
* Hotpoint (similar?) auto clean; https://www.youtube.com/watch?v=a9cgkHlb6Fg
* Hotpoint (customer) Demo; https://www.youtube.com/watch?v=qSEGjd0HGBg
1helpful
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
How do I get out of demo mode
The DEMO mode is a setting in your TV and not your DISH receiver. For most TVs, use your TV remote, hit menu, and dig around until you see an option to reset all settings, or something phrased the same way. The TV should turn off then on, then ask you to set up your TV again. If you need more info, check your TV's owners manual.
'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
5helpful
Cant get out of demo mode
press and hold both the On/Off button and the Start/Reset button until "D off" is illuminated in the display you should then be able to select wash programme as normal
Hotpoint WD129 Wash programme stuck
i am having the same problem with my widl126 washer.
ant help?
Washing programme information
You can download the manual from the link below: http://www.serviceforce.co.uk/pdfs/U23117.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
