Question about IBM NetVista PC Desktop
Some windows file is corrupt so the IT person at my company said i can remove the hard drive and hook up this cable to it and get all the files off and onto another computer. So i wanted to know how to remove the hard drive
  • 245 Answers
Hi
I hate to copy and paste an answer,but this is exact and concise.
"You can free the front panel--which exposes two front-mounted USB ports--by pressing a clearly marked blue button on the back. With the interior exposed, the hard drive tilts out when you pull on two blue handles. After you disconnect the power and IDE cables, the hard drive slides out the front of the case when you disengage two blue tabs. You can remove the hard drive in seconds--handy for protecting data."
If that doesn't help,post back with any questions and I'll try and help.
Bob
Posted on Aug 19, 2010
    Sergeant:
    Champion:
  • 310 Answers
If you are not sure on how to remove teh hard drive, I'd suggest you get an expert to do this. The reason being, 1. Your computer has to be powered off 2. If , while removing your HDD, any other cable comes out, you should be able to plug it in. Its better you get someone who is well versed to try this out .
Data Recovery Software
Maybe you can try uFlysoft Data Recovery for Mac, it can recover empty trash on Mac only in three steps:
Step 1. Launch the software to scan the device where your files deleted
Step 2: Preview the scan result files and make mark if it is the one you find
Step 3: Recover files
Mac Data Recovery Recover Lost Data with Ease
Jun 06, 2015 | Data Recovery Software Computers &...
Western Digital External USB 3.0 1 TB Hard Drive: The disk is inaccessible. The file structure is corrupted and unreadable
There is companies that make data recovery, you could try them, there is also some for private use, but they are not that good. But those companies will pay a lot, if you have a good home insurance you could try them to pay recovery.
Depends how much you appreciate the information on hard disk.
Jul 23, 2012 | Computers & Internet
Samsung N150 ntldr is missing, how can i fix that problem
Common Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Apr 18, 2011 | Samsung N150 (36725723009) Netbook
I can not copy or remove files tot mine extern harddisk Maxtor and the error shows 0x80070571. What can i do? How to repair I have already done cksdsk but is does not help
There are several things that come up for this error message.
1. The files you are trying to copy over to your external maybe corrupt. (What type of files are you trying to copy, windows files or just personal data ?)
2. Your External HDD is either damaged, or not hooked up correctly. Make sure all cables etc are secure and working, try a different set of cables if possible.
3. You can try this tool that will analyze your hard drive for problems. CLICK HERE.
Post back if you have any questions or comments.
Mar 21, 2011 | Computers & Internet
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
NTLDR is missing in my computer
Missing NTLDR can be caused by any one of these problems :-
Corrupt NTLDR and/or NTDETECT.COM file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Failing to enable USB keyboard support in the BIOS
With Windows XP follow these instructions
If this doesn't work, then the last resort is to install Windows again, plus the computers device drivers and your programs.
Feb 11, 2010 | Computers & Internet
Missing file or corrupt windowssystem32 hal dll how to fix if I can't fix it can I do a full system restore with an xp disk and driver disk from another computer?
You can put in your Windows disk and boot PC from the disk drive and then select to repair, this will not format your PC and will replace your hal.dll file. fixing windows and keeping your personal files.
Usually this works, but if it can't fix the problem it will tell you then give you a format option, at that point turn off the PC, take out the hard dive, hook it up to another pc as a slave or external drive to back up your files, then put the thing back in your pc and format.
but try to use the repair option of your windows disk. there is hardly ever an actual reason for people to format
Jan 02, 2010 | Computers & Internet
HI my sons acer travel/mate 6292 has crashed and will not boot up, the screen is black but its stating the NTLDR is missing and asking to press ctrl,alt, and delete to restart, yet when I do this it goes...
Hi tracey,
Cause for the NTLDR missing:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable. are
Solutions:
Windows XP users
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
ENJOY! RATE THIS SOLUTION RNJ VINOD KUMAR
Jul 03, 2009 | Acer Aspire 5610-4648 Notebook
Have ide drive have put a new 60gig but cant load new os it finds the cd drive but wont boot from disk have changed bios but still it say ntdlr missing it drivin me nutts.
  5. Attempting to upgrade from a Windows computer that is using FAT32.
  8. Seriously corrupted version of Windows.
  10. .
To Fix
Jun 01, 2009 | Fujitsu Siemens LifeBook S-6000 Notebook
Data recovery from corrupt external hard drive
Well, in your case you should format the external drive and then try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Dec 07, 2007 | Computers & Internet
IBM NetVista PC Desktop Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
