Question about Onkyo M-282 2-Channel Amplifier
How can I connect onkyo m-282 power amp to onkyo TX-SR505 receiver? thanks for your help
    Problem Solver:
  • 6 Answers
Your receiver must have a pre amp out on the back.
Posted on Aug 20, 2010
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
How to connect android movie box (Mx3) to TX-SR505 receiver
The TX-SR505 does not support Video Streaming, Thanks, JT
Dec 19, 2015 | Onkyo TX-SR505 Receiver
I have an Onkyo TX SR505 receiver which for some reason, while watching TV or listening to music, there will be a click heard in the speakers and the sound will be gone. I'll shut off the receiver and turn...
It's probably self-protecting from heat build-up.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 19, 2011 | Onkyo TX-SR505 Receiver
How do I hook up my Onkyo receiver to my dish network box?
Take the cables from the receiver to the tv and connect it to your Onkyo where it says "in", then take another cable and run it from your Onkyo receiver where it says "out" and connect it directly to the tv. Make sure you cycle the inputs on your receiver and tv, so you get sound and video.
Daniel Busa
DISH Network Customer Service
Jan 05, 2011 | Onkyo TX-SR505 Receiver
SR573... Does it support NTSC/PAL?.
There's no mention of either NTSC or PAL in any spec sheet.
This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
http://www.onkyousa.com/model.cfm?m=TX-SR573&class=Receiver&p=s
The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220-240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Some aliases for the SR575=
TX-SR505
TX-SR505E
TX-SR8550
TX-SR575
You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
Apr 07, 2009 | Onkyo TX-SR573 Receiver
TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Mar 18, 2009 | Onkyo TX-SR505 Receiver
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Hum in Onkyo TX-SR505
I know that this is not Cheap But, If you want this to go away you need to Upgrade the A/V Cables to Monster Cables and it will Fix this Problem!
Dec 30, 2008 | Onkyo TX-SR505 Receiver
Loss of video signal from Onkyo TX SR 875
Go to hardware set up and turn off the hdmi audio output,sounds daft but it should work,also make sure the B speakers are not on as this puts the menu up the left.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR503 Receiver
Onkyo M-282 2-Channel Amplifier Logo
311 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
