Question about Kirby Ultimate G Bagged Upright Vacuum
How do I replace belt on 2001 G kirby vacuum cleaner ?????
  • 112 Answers
SOURCE: Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
Hope that helps!!!
Posted on Apr 08, 2008
b0sslady2001
  • 357 Answers
SOURCE: kirby shampoo instructions how to assemble shampooer
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
This is also a great place to order Kirby supplies!
Posted on Jun 22, 2008
Arius
  • 446 Answers
SOURCE: how do you install the belt on the kirby vacuum
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Posted on Nov 27, 2008
SOURCE: How to replace just the Kirby 210097 Hose End For
If you just grab it where it swivels and pull with a slight bending motion the plastic "bayonet" section on the end of the hose will pull out of the plastic housing that attaches to the vacuum. Don't pull on the corrugated hose section or you will ruin the whole assembly.
Posted on Jan 31, 2010
VacuumRepair
  • 438 Answers
SOURCE: how do I replace the drive belt on a Kirby G5
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners including your Generation 5 (G5). The belt change procedure is the same for Kirby Models G3-G10 Sentria. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J
Posted on Mar 21, 2010
How do I replace a belt in my classic iii kirby vacuum cleaner
The below link leads to an excellent video on replacing the belt. It's for a newer model, but I believe they're pretty much the same.
http://www.kirby.com/Portals/0/videos.html
Jan 15, 2011 | Kirby G4 Bagged Upright Vacuum
Tip
How To Replace The Belt On a Kirby G6 Generation Vacuum Cleaner
Greetings,
Below we have recorded a video on how to replace the belt on a Kirby Generation Series G6 Upright Vacuum Cleaner. This easy to understand video will explain step by step how to change the belt, as well as service the roller brush. Learn how to lower the brushes as the beater bar wears out, and how to prolong the life of your belt by doing regular maintenance on the roller brush.
The repair is the same for all Kirby Generation Uprights. I hope this helps everyone! Feel free to contact us if you have any questions about vacuum repair.
If this video was helpful, please be sure to rate it as helpful by clicking the thumbs up icon at the bottom of the repair. Thanks for watching!
Chris J.
GoVacuum
on Mar 20, 2010 | Kirby G6 Bagged Upright Vacuum
Tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Jun 02, 2010 | Kirby Heritage II Vacuum
How do you replace the belt on my Kirby G5 vacuum cleaner?
Hi There,
We've created a great video demonstration on how to replace the belt on Kirby generation vacuum cleaners. This will walk you through step by step on how you can replace the vacuum's belt, as well as do the basic maintenance on the roller brush to prolong the life of your belt.
I hope that this video helps you! If so, please be sure to rate my repair by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Thanks again,
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
How do i replace my belt on my kirby vaccum cleaner
Please see the following video we've shot on how to replace the belt on a Kirby Generation vacuum cleaner. This should explain to you step by step the procedure to replace the belt. If you need to purchase a belt, we can also help you with this.
Feel free to request a repair clarification if you have any questions I can answer.
If you found this repair helpful, please be sure to rate the repair by clicking the 4 Thumbs Up Icons in the top right hand corner of the repair. Thak you so much.
Chris Jones
GoVacuum
Mar 20, 2010 | Kirby G4 Bagged Upright Vacuum
How do I replace the drive belt on a Kirby G5 vacuum cleaner?
Greetings,
Chris J
Jan 20, 2010 | Kirby G5 Bagged Upright Vacuum
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
Greetings,
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How do you install the belt on the kirby vacuum?
Step 1:
Step 4:
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
249 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
