Question about 3002 2 Way LED Car Alarm Keyless Entry System
I have a Viper Alarm 3002 2-way on a 2003 Mustang GT. After removing it, my car no longer starts. Please help
  • 32 Answers
If your car doesnt start, maybe when you pulled out the alarm, you didnt connect the starter wire back together
Posted on Sep 11, 2010
  • outkast99 Sep 11, 2010
    look for a white wire with a pink stripe in the ignition harness if this wire is cut in half, you must connect both ends together.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Viper 5806V Remote Issue
Maybe the battery in the remote is getting low.
Jan 12, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Ford mustang wont start my 2002 mustang wont start it has a viper alarm system on it.
You need first remove the alarm then check if it start. Or put the ignition on make sure the vehicle is in park if it is a automatic transmission. Or in neutral with emergency brake on hot wire the stater.
Oct 03, 2013 | Viper Vehicle Parts & Accessories
2005 sedona alarm
Please be more specific. Is it the factory alarm going off when you remote start or, is it the Viper alarm going off when you start the car with the key?
Jan 24, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Should I intall a Viper 5701 remote start on a manual transmission Mustang?
Honestly, you would be taking a risk. You have to remember that if you do, you will always need to keep the car out of gear in order to start the vehicle. You will also need to install an extra relay in order to bypass the clutch switch. Very unsafe, but good luck.
Feb 19, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Had this viper alarm installed on a mustang and the alarm seems to go off every 30 minute
If your alarm is going off every 30 minutes its because a zone is backfeeding after the cars computer shuts down. First you have to find out what is back feeding... I would first disconnect the door trigger wire from the alarm to the car. Test it and if this is the problem then you should go to the latch wires of the car doors and not the interior domelight. If the problem is still there than you should check to see if the trunk trigger is the problem. Most techs pick up the trunk trigger in the trunk at the light. if you find that this is the problem then just remove the trigger from the light and add a pinswitch in the trunk.
Dec 28, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
3002 2 Way LED Car Alarm Keyless Entry System Logo
211 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
