Question about Craftsman Convertible 25cc. Gas Line Trimmer
How do you put on new trimmer line on a dual feed weedeater
    President:
  • Craftsman Master
  • 1,545 Answers
Enter you machine's model # @ www.searspartrsdirect.com and download your user manual. They will explain this better than I can and have diagrams you can look at to assist.
Posted on Aug 19, 2010
How to change the fuel lines in the 128 Ld Husqvarna Trimmer
Buy some new fuel line then put the line in from the motor side into the tank and feed up and through the opening on the tank. Then you can put on a new filter with a tiny clamp then put it back into the tank making sure the filter is resting on the bottom.
Apr 22, 2015 | Husqvarna 128 LD Weedeater
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Need to change the weedeater line.
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Sep 29, 2010 | Homelite Mighty Lite Lawn Trimmer
Weed Eater Straight Grass Trimmer, 25 CC, 17-in. The trimmer line releases too easily and wastes most of the line.
Some of the weedeater heads are known to be ineffective and quite troublesome. Try Home Depot maybe for a universal type head that will hold and feed line the way you want. They have strimmer parts.
Aug 30, 2010 | Garden
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
My weedeater with auto line feed will not stop feeding the line when in use.
Did you ever get an answer to this problem? I'd like to know because I have the same problem with my cordless 14" Black N Decker Gass Hog. I rethread it, but the line continually feeds and is out in about 2 minutes.
May 03, 2010 | Black & Decker String Trimmer Cordless 12"...
Weedeater quick snap line spool
the part you bump on the ground to feed new line unscrews but typically its left hand threads so you think you are tightening but actually loosening. once off the spool chould come out then you may can tap on the head with a hammer coaxing it to come off.
Aug 04, 2009 | Garden
Installing new line on my string grass trimmer
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a weedeater brand weedeater and need to know how to take the spool off so I can wind more line on it?
if its the newer type all you need to do is grab the black knob at the bottom of the trimmer head and pull it carefully straight towards you and it should pop off
wind line on the spool in the direction the arrow shows you there is a small hole you put the line in to start the line before you wind it it is labeled .065 or .080
wind about 10-15 feet of either .065 line or .080 line and lock the line in at the edge of the spool and thread the excess thru the hole and push spool back on and pull each line until it unhooks from where you locked it in .
this is the directions to the weedeater heads and spools mostly used on this product.
if its two lines then pull out 20 feet of new line cut it and put the two cut ends side by side and insert the cut ends into their respective holes in the spool and wind in the direction of the arrow until you wind to the loop then cut the loop lock your lines into place and thread it thru both holes keeping the lines kind of tight and push the spool onto the housing as it snaps in pull each line to unlock it from where they were held so the bump feed will work.
hope this helps you
Jun 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman Convertible 25cc. Gas Line Trimmer Logo
266 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
