Question about Toshiba Computers & Internet
I AM HAVING A PROBLEM WITH A TOSHIBA LAPTOP IT IS NOT COMING ON THE SIDES OF THE LAPTOP IS GETTING HOT AND NOTHING IS SHOWN ON THE SCREEN
  • 64 Answers
I would leave it for 10-15min with the battery and power unplugged. Then just plug in the power adapter and start it without the battery. Also make sure while using it keep it propped up. Put a pencil or pen at the back end of it just so there is a little airflow under the laptop. -Ravi Shanghavi
Posted on Aug 19, 2010
Need a manual for Samsung 4G so I can hott spot my laptop
no you don't need a manual its easy
Go to your normal home screen on the phone . Ie unlock the screen.
At the top of the screen you will see small white symbols .
put finger on them and pull/ drag finger down to see hidden menu
You will now see wi fi , location, sound, screen rotation, bluetooth
put finger on right hand side of these options and drag finger left
the forth option shown should be mobile hot spot
press on mobile hot spot with your finger
Attention
Enabling mobile hotspot will turn off wi fi
Cancel or OK
Click on OK ( you use wi fi to link the mobile data to the laptops , ect)
on your laptop you will see androidap as a wi fi network connect laptop to this !
network key come up
what is the password
go into the phones settings
look for Tethering and Mobile Hot spot
click on this
click on Mobile Hot spot
step 3 in list of instructions that have now come up will be the AndroidAP password you will need on the laptop , ect
Put password listed into laptop wi fi connection password question.
PS put mobile on usb power or usb charger while hotspotting !
Dec 08, 2017 | Samsung Cell Phones
Toshiba satellite C655D screen fuzzy and now nothing
your inverter may have just shut down,it is behind the screen at the bottom.or your screen may have gone..try putting a monitor using a vga cable to your laptop,if the monitor comes on then get the screen checkd and the inverter.
Jun 14, 2014 | Toshiba Satellite Computers & Internet
I recently got my toshiba satellite laptop home from being repaired by Toshiba ( a screen fix), and when i turned it on, the wireless switch would not work and the hot key (Fn+F8) did not work either. I...
I would contact Toshiba immediately and let them know that you experiencing that issue.
Depending on how they repaired your screen they could have accidentally damaged the motherboard or forgot to connect the wifi cables that run along side of the lcd back to the card.
Feb 15, 2011 | Toshiba (PA3212U) Wireless Adapter
Toshiba satelite L500-00W, had suddenly shut off while in progress as to be a black out. I can put the power on but I hear the fan barely and the screen doesn't come on. It goes on but nothing is shown for...
ok try the laptop on a pc screen on the side of your laptop is a socket for a moniter to be pluged in if that works then its the screen try also a light shining onto the screen sounds like the screen reg is gone
Mar 13, 2010 | Computers & Internet
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Laptop boots up but after nothing.
Hard drive is shot. replace and then re install operating system
Jul 05, 2009 | Toshiba Satellite M45-S265 Notebook
No picture; nothing on screen
In most cases there is nothing you can do.Its a systemboard failure.And the systemboard needs to be replaced.
May 06, 2009 | Toshiba Satellite M35X-S149 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
No screen
Does the initial Toshiba screen come up before the Windows count down screen? This is the Toshiba, right?
Aug 23, 2008 | Toshiba Tecra M1 PC Laptops
Touch pad is on fire!
same laptop but intel core 2 duo, and I got the same problem , my touch pad is very hot sometime and I have the cooling fan underneath the laptop it's help! and after that like couple weeks later my laptop was death it wasn't boot the vista. it shown the options like 1. fix the ..... 2. start normally.
when I choose No.1, the screen turn BLANK all day and nothing changed and I power shut down and choose No.2, then it boot!! But the programs were not boot well and stuck like not completed. SO what's wrong with it???
Aug 04, 2008 | Toshiba Satellite A135-S2386 Notebook
Computers & Internet Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
