Question about Endless Summer Heating & Cooling
Burner will not light. With the pilot light burning and the gas is turned-on to ignight the main burner the pilot light goes out.
    Master:
    Sergeant:
  • 449 Answers
Call aservice tech your pilot light might be blocked therefore the pilot flame might not be strong enough to handle the puff of gas when the gas valve opens ps. if the unit is off in the summer spiders are usually the problem. Hope this helps
Posted on Aug 19, 2010
Pilot light doesn't stay lit
The thermocouple may have failed. It looks like a copper wire that goes from the gas valve and leads to the pilot light.My first thought is that the pilot light burner is not burning hot enough because its got dust in it or a spider web blocking some of the air it needs to burn hot. If the pilot stays on long enough to bring the main burner on, a dirty main burner lighting rough will cause the pilot to snuff out. To do the actual repair I would suggest that you contact the manufacturer on the internet. Getting up to your elbows in a gas appliance without professional help is asking for dangerous serious trouble. Good luck.
Aug 17, 2013 | Honeywell Water Heaters
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
MAIN BURNER SHUTS DOWN JUST AFTER IGNITION FLAME RODS TESTED VENT CHECKED
The Thermocouple or Thermopile has failed and needs to be replaced. The Thermocouple is a safety feature that keeps the pilot burning if all operations of the gas valve are safe. If the pilot burns, the burners will light. The Thermocouple shuts off the gas control valve if the pilot goes out.
Mar 08, 2011 | Heating & Cooling
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
Pilot light keeps going out
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
Oven pilot light is on, but burners will not light. pilot light burns larger when trying to turn burner on. Do I need a new thermostat?
The thermostat is doing it's job if the pilot gets bigger. When you turn on the thermo, it does 2 things: Makes the pilot bigger and supplies gas to the oven safety valve in the oven. The bigger pilot heats up the bulb from the valve and the stuff inside expands and turns on the main gas. The oven cycles when temo is reached by making the pilot smaller. The most common problem is that the pilot doesn't get big enough to satisfy the valve. Take out the pilot burner ***'y. (7/16" wrench for the nut). Replace the pilot burner. The part is probably a 5414S030 if the valve bulb is located parallel to the ***'y.
Sep 30, 2009 | Magic Chef 31000 Gas Kitchen Range
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
Heating & Cooling Logo
171 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
