Question about Pioneer VSX-D510 Receiver
Amp err turns on then turns off - Pioneer VSX-D510 Receiver
    Problem Solver:
  • 17 Answers
YOU CAN GET SERVICE MANUAL FROM HERE electrotanya.com http://elektrotanya.com/pioneer_vsx-d510-rrv2439_av-multi-channel-receiver.pdf/download.html
the amp is going into protection mode ...normally one of the amplifier modules are faulty..check for DC on speaker outputs just as you turn on from standby...find the 1 with dc on it normally .identify amp module from manual change modules ic ..jod done...sounds simple put it isnt...yammandan
Posted on Aug 19, 2010
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
My Prolem .DDL 9000a Err-71 & Err-007 I went Solutions
hello there
first please tell me the model of control box? is that error appear emmdiatlty when turn power ON? please email me at ( aabozid@hotmail.com ) i will try to do the best to resolve this problem.
best regards
ashraf abozid
Oct 20, 2011 | Juki DDL-8700
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
Amp Err
please check all speakers cables for short circuit-disconnect all speaker-put volume low-wait and observe it if no shut down -go to next step-connect your speaker one by one until you find the bad one,start with speaker cable(try another good cable) and then speaker.if shut down happened again while you connect nothing to your system you will have inside problem and ask for service center to fix it.
Jul 07, 2008 | Audio Players & Recorders
Receiver standby/on switch is flashing and cannot turn receiver back on
Try checking your speaker cables as one of them may be touching the case of the amp,or touching another cable,this can cause a short and cause the error message.The amp is protecting itself .
hope this helps.
CABLE GUY.
Jun 30, 2008 | Pioneer VSX-917V-K Receiver
Sreen says amp error
The audio Amplfier IC are damaged.
May 22, 2008 | Pioneer Audio Players & Recorders
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-D510 Receiver Logo
268 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
