Question about Vacuums
I have a very old carpet shapooer an electrolux b28 and i dont know how to make the brushes stay on
5 Suggested Answers
b0sslady2001
  • 357 Answers
SOURCE: G5 -HOW DO I ATTACH THE CARPET SHAPOOER?
Here's my online guide for using the Kirby shampooer....
http://reviews.ebay.com/KIRBY-CARPET-SHA...
HOPE IT HELPS!!
Marci
Posted on Dec 05, 2007
  • 260 Answers
SOURCE: Brush assembly will no longer spin on carpet however the suction from the system is still good. Unit is only 5 years old.
Open and check for belt damage. Also make sre there isn't debris causing this error.
Posted on Apr 16, 2009
ftw1952
  • 10319 Answers
SOURCE: hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Posted on Jan 24, 2010
SOURCE: Electrolux el7020b is making a clicking noise?
You need to change the belt
http://evacuumstore.com/c-99-electrolux-belts.aspx?manufacturerfilterid=0
Posted on Apr 17, 2010
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
My brush piece is corroded
El8807 - call customer service at 800-896-9756 push 1 or 2, then push 3. They sent me a new replacement, no cost. Need your Serial Number so they know date of purchase. 5 year warranty. Best vacuum ever, better than dyson and cheaper by 100%, but the brush stopped working after getting tangled. Called support and they replaced. Great. Cheers!!!
Apr 21, 2014 | Electrolux EL8807A Precision BrushRoll...
Floor scrubber
You can often find them on Ebay. Just look for Electrolux or Aerus Floor Pro brushes. You can probably also find them under Electrolux shampooer brushes.
You can purchase them from the Aerus site and they will ship to you: https://www3.aerusonline.com/Electrolux/index.asp
Or go to http://www.aerushome.com/storelocator/ and follow the directions for the dealer nearest you. If close enough you can pick them up at the store, they can deliver to your door, or they can ship if you live several miles away..
Jun 08, 2013 | Electrolux Vacuums
Hey everyone, first time on forums. I have a Eureka True Clean vacuum that I found in the garbage. I have disassembled everything, cleaned and restored it. Looks perfect now. Suction from hose is powerful,...
Change the belt on the unit, and adjust the height adjustment until the brushes are just touching the carpet. I know you mentioned the belt looks good, but when you get the new EXT-U belt, you will notice a size difference. Good luck!
Jan 25, 2012 | Electrolux Vacuums
Can I lift the vacuum beater bar higher up? Bought new carpet and would like it to push smoother!!! Bought a shag carpet
No. The Electrolux (Aerus) uprights are auto adjusting to the height of the carpet. Make sure the brush is spinning when the vacuum is on. If it's not, this will cause difficulty in use.
Apr 06, 2011 | Electrolux Epic 3500 Vacuum
The carpet sweeper on my electrolux stopped working....used it for a little bit and then it just stopped
Make sure the brush is cleared and clean, press the reset button, and try again.
If the motor runs, but the brush doesn't turn, it's likely due to a broken belt. Have it replaced by someone who knows what they're doing.
I strongly recommend taking it into an authorized shop.
Dec 04, 2010 | Electrolux Vacuums
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
Apr 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
96 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
