Hm, there is a hi limit switch between the range top and oven cavity. Ck your door to see if its sealing . If heat is escaping have a servicer look at your hinge receivers so the door will seal.
Go to radio shack site. There is probably a manual you can download if you search the site. The catalog number for the scanner is 20-427. you can search by that number if the model number does not work.
Sounds like the amplifier of the audio section is out. I am guessing it is out of warranty, otherwise you can return it for repair. Other than having it repaired at Radio shack or another electronic repair place, the cheapest solution is to buy an amplified speaker and try it in the first the external speaker jack on the rear or the head phone jack in front. In effect, you are bypassing the damaged section and amplifying the audio you do have.
