Question about D-Link DIR-615 Wireless Router
Install stepd on initial set up disc is not coming up.. my computer shows not responding
    President:
  • 1,768 Answers
11. the disk may be dirty . Wash with dish detergent and warm water and a cotton towel or microfiber cloth . ( do not use a paper towel ).
2. check to see if you can load any other disks in the DVD or cd rom tray to see if they come up if so then the disk may be corrupted and you will need a replacement disk.
3. check here for a firmware update for your model.
http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
4. There is also warranty support :
Here is the information :
Questions:
Contact Information
Try Our New Intelligent Chat Service For Tech Support.
For installation support within your free service period or for warranty authorization within your warranty period, call
1.877.453.5465
24 Hours
7 Days a Week
For technical support outside your service period, outside of free support scope, or with third party products, call
1.888.814.2882
6:00 AM-10:00 PM
Pacific Time
7 Days a Week
Visa and MasterCard Accepted
Click to email Tech Support
Looking for After Warranty Support? Premium Services
Posted on Aug 19, 2010
Operating system not found
Unfortunately, Acer PC's do not come with an Official Microsoft Install Disc, however, you should be able to reset the computer to its original factory setting(s), by pressing either F10 or F11 at the initial start-up of the computer, not the start-up screen of the operating system. If this does not work, even though it should as long as you have not altered the HDD internal disc drive to the point to were you would have removed this factory installed reset function. In the event that this setting is not found or available, one other option is to connect an external CD/DVD-ROM Drive to the computers USB port load a copy or an original Microsoft Install Disc into the CD/DVD-ROM Drive. Turn your PC on and at the initial start-up screen of the computer, not the operating system start-up, access the computers bios screen, or boot order screen and adjust the computers settings to boot initially from usb port/external hard drive/CD?DVD-ROM Drive. If your computer allows you to do such, you should be able to re-install the operating system, be it the same or a newer windows version or some other type. NOTE: If you have the know how, you can download free operating system online for free, and creat your own "boot-able" flash drive...
Nov 16, 2012 | Acer Aspire 7741z
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
Bootmgr is missing
If Office Depot "cleaned" your hard disk, then there is nothing remaining on it. You will need to load the recovery media cd/dvd's you created or purchased in the proper order to have them restore the computer back to its initial configuration when you purchased it. Put the first CD/DVD into the drive and then power off the machine & power it back on. The installation should begin. I'm sad OD wiped out your mothers drive.
Mar 18, 2017 | Samsung (SP1203N) 120 GB Hard Drive
My computer not responding when dvd disc inserted
Again Install Windows and then install PowerDvD to fix this problem.
May 31, 2010 | LG SecurDisc 20x External Double-Layer DVD...
I installed a Seagate Barracuda 1.5TB Hard Drive as a removable hard drive on a Gateway LX6200 running Windows 7. It says the software installed and it is ready to use, but when I go to ''computer'' to see...
Go to the contro panel > Administrative Tools > computer management > Look in the left side pane and click on "disc management". Your drives will appear here including ones that may not be "initialized". If you see a drive that has no letter, maybe just a number like drive 03, this drive is not initialized and needs to be done if it is to be recognized by the computer. With the disc management window open, look where it lists the disc. Your main hard drive should be disc 0. If this external is connected via a usb, this disc maybe listed as disc 01 or just 1. Right below the name it will say that the disc is offline. If this is the case, right click in that gray area where the name is and click on "initialize". A series of windows will open asking you to click ok on what kind of drive it is to be used for. Just go with the choice that is already given and click ok. The drive will then be initialized and it will then be ready for formatting. Simply right click on the area next to the name that says unallocated and select format, choose ntfs file system and the size of the partition if you want to make several partitions, this is the time. then choose quick format. The drive will the make the partitions and give the partitions drive letters. Your drive is all set up.
If it comes up and says that "the device is not ready" when you try to initialize it, then the drive or the interface is bad.
Dec 26, 2009 | Seagate Barracuda ST31500341AS 1.5TB 32MB...
Maxtor 1TB hard disk in the sky HD box failed
I would like to try something here. I would like you to hook the hard drive up to your computer either through the enclosure or better if you have a usb adapter that simply slips onto the sata connector. Once this is done listen for the tone of the computer recognizing the device. It doesn't necessarily have to be recognized as a hard drive. Now, open the control panel and open administrator tools. Open computer management and on the left pane near the bottom click disc management. All of the discs currently hooked to the computer will show is the right pane whether they are active or not. If the disc shows here than it is alive and can worked with. Right click on the disc in question and see if it gives you the option to "Initialize". Some of these enclosures that have their own firmware will sometimes de-initialize a hard drive that has been previously activated. If this is the case, then you can "initialize this disc once more and partition it for use. You will lose your data but the drive will be useful once more.
Sep 06, 2009 | Maxtor Hard Drive
I have a insperion 8100 laptop, I replaced the 20 gig hard drive with a new 100 gig drive. my bios is the latest update A15. It wont reconize the new hard drive, F1 and F2 will give me the same info no...
Sounds like the new drive is not "Initialized" The drive should have come with software that initializes and formats the new drive. After installing the new drive, boot the computer with the included software disc. Seagate and western digital have software that comes with their drives. If that is not possible, the other way is attach the drive to another computer, access the control panel > Administration tools > computer management > scroll down left pane and select "disc management" > this pane will show all hard drives on your system, including the new one. If the new drive does not show a partition in the right pane, then you have to RIGHT click on the name of the drive, which is the small tan box to the left of where the partition would be and select "Initialize" this is done immediately and is active immediately...no waiting. Disconnect the drive and re-install in the laptop.
Aug 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Garmin etrex Topo Great Britain disc
just completely uninstall first the GPS software/program that is currently on your PC, then after it ws completely uninstalled try again to insert again the CD and install the program...
let me know..
Jul 07, 2008 | GPS
Pioneer DVR-112D disc recognition
what i would do is install one drive as the master on ide 2, and the other as the slave on ide 1 and what OS are you using?
Sep 13, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
D-Link DIR-615 Wireless Router Logo
82 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
