Question about Sector 600 2653917025 Watch
Sector sge 650 watch. resetting after battery installation. stop watch second hand defaulted on 42
3 Suggested Answers
  • 40 Answers
SOURCE: after a battery change the stop watch hand not
Pull out the crown and then press the chrono pushers to advance the chrono hands.
Regards
Posted on Aug 19, 2010
escapement
  • 2334 Answers
SOURCE: resetting a sector adv 2500 after battery change
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals. Rate me, please .
Posted on Apr 08, 2010
How to set the date in sector sge 650 2653960035 watch? Thanks.
Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
Jan 16, 2013 | Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Resetting a sector adv 2500 after battery change
    Apr 08, 2010 | Sector 250 3253251115 Watch for Men
    Guess Watch's stop watch is broken?
    it's not broken.
    let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
    to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
    Aug 05, 2009 | Watches
    Second hand jumping
    If your model is not an automatic movement then it means your battery is too low in remaining power to support the watch.
    Jan 23, 2018 | Tag Heuer cj1110.ba0576 Wristwatch
    SECTOR CHRONOGRAPH 200 WATCH
    That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
    Sep 19, 2007 | Watches
    Sector 600 2653917025 Watch Logo
    519 people viewed this question
    Top Sector Watches Experts
    staicuma
    Level 1 Expert
    aravind shet
    aravind shet
    Are you a Sector Watch Expert? Answer questions, earn points and help others
