Question about Jenn-Air Refrigerators
My ice maker is not functioning properly.will not produce ice.Water maker does work.
    Champion:
  • 245 Answers
It is your inlet valve. behind the refrigerator where your water line is connected. Most refrigerators the water dispensor will work without the icemaker. If you have no water entering your fridge into your icemaker then it is your inlet valve
Posted on Aug 19, 2010
Sea Breeze
  • 4654 Answers
SOURCE: ICE MAKER
Your ice maker works off a different side than the water dispenser. Most times the water control valve is the problem yet it has 2 sides one for water and the other for ice. You can check the ice maker by filling with tap water. Let it freeze and if it dumps the ice and tries to refill I would say the water control valve part number 4389177 will need to be replaced. Sea Breeze
Posted on Aug 25, 2009
  • 1314 Answers
SOURCE: Ice Maker Isn't Working Anymore
yes the door dispenser and the ice maker have separate valves it could be the ice maker valve isn't working properly could be the motor module is bad on the icemaker its self get a 10 gauge piece of wire about three inches long strip about 3/8 to1/2 in off each end pull the front off the icemaker and you will se a bunch of little holes they will have letters on them put the wires in the holes marked t and h kind of wiggle it side to side and watch the ice maker if it does nothing then replace the motor module on the front of the icemaker (you don't have to buy the whole icemaker you can buy the module separate ) if the ejector blades move then when they get to the bottom pull the wire out wit for it to complete its cycle see if it fills if it doesn't then change now if your ice bucket is in the door that can be a whole different animal reply to me and let me know what you find and if you have the icemaker in the door dont buy anything till we check it out as a mater of fact if you pull the bottom kickplate off there should be a tech sheet in it or in a plastic bag under the fridge
Posted on Feb 20, 2008
  • 44 Answers
SOURCE: ice maker not producing ice,already check the basic problems,
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Posted on Jun 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: ice maker is not working. I hear water running to
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjjhfkj
Posted on Sep 30, 2010
Ice machine not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
The fan at back does not come on. The fridge make a clicking noise, The fan tries to run... Also it does not pump water anymore. It does make ice
  1. Dispenser switch
  1. Door switch
  1. Feeler arm
  1. Ice maker heater
Aug 16, 2014 | GE GSS22JER Side by Side Refrigerator
Maytag freezer wont produce ice
You have two sides to the water control valve. One side is for the water coming from fountain and the second side is to refill your ice maker after each cycle of dumping ice into the ice bin. The freezer should be a 5 degrees or below for the ice maker to function properly. If the ice maker is empty then fill with tap water up to top edge of the ice maker and allow to freeze. If after the water freezes and dumps the ice into the ice bin the ice maker does not refill I would recommend replacing part=> 67006009 Dual Water Control Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Replaced icemaker with new one but still not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG refrigerator french door icemaker not working
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
Oct 10, 2008 | GE Refrigerators
Refrigerators Logo
82 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
