Question about Dell Latitude D505 Notebook
Computer works fine but the charger does not work but will work on other computer exactly the same. what do I do?
    Sergeant:
    Champion:
  • 310 Answers
I think its an issue with the pin in the laptop. Havent seen a lot of those. I would suggest you talk to the Dell Contact center and get a replacement .
Posted on Aug 19, 2010
My daughter's Dell Latitude E5500 won't charge. If I plug her charger into my exactly the same model - works fine. The moment the power lead touches her input port, the light goes off and then the cha
1. Does YOUR charger work on her computer? If yes, you need to replace her charger.
2. If YOUR charger doesn't work on her computer, then the problem is most likely a broken power jack (or a "cold solder joint" on the power jack). The power jack is mounted directly on the motherboard, therefore the entire computer needs to be disassembled to repair it. Here's a link to a YouTube video showing this repair:
https://www.youtube.com/watch?v=OoT9XVn5Y2s
Best of Luck!
Oct 11, 2014 | Dell Latitude E5500 Laptop
I have no power no icons it will not turn on
There are a lot of possible reasons why your computer isn't turning on. Here are the things that you can do to identify the reason of the problem.
Remove the battery and use the charger to power up your computer. If it turns on well, then replace the battery in your computer. If the charger does not turn on your computer, then check the charger if it's still working fine or the port where the power charger goes. Check if there are signs of damages in the port of your computer.
Let me know if you have any questions.
David
Mar 30, 2013 | Computers & Internet
Trying to order battery and new power supply for computer 96254
Without the Make, Model of computer It's difficult to help. But a word of advise, Beware of inexpensive aftermarket Batteries and cord/chargers. They sometimes , at best, do not work properly, a worst, can be a fire hazzard. It's cheap for a reason. Be sure to buy the EXACT power specs, Voltage, Amperage. Look to the Laptop Manufacturer for exact replacement. They may be pricey, but , in the long run a better bet.
Dec 02, 2012 | Computers & Internet
Hi There, I have a HP Pavilion ZE4900 and recently the AC plug in won't work. I have taken the battery out and put it in another comuter that is the exact same and it charges fine, I put my battery in the...
If your computer won't charge the battery, but the battery charges fine in another computer, and you are sure that the charger is good, then your problem is probably the DC power jack. If you wiggle the end of the power cord where it attaches to you laptop, and it starts charging properly, then the DC power jack is broken.
Apr 26, 2010 | HP Pavilion Ze4900 Notebook
7200t thinks it's connected to computer when charging
Bad charger - not powerful enough, Use a Gomadic charger with tip # 24. Works for me.
Aug 29, 2009 | Navigon 7200T GPS NAVIGATOR PERPW/ FREE...
I have the same exact problem with me dell laptop
DID YOU CHECK THE CHARGER? KINDLY CHECK FIRTS THE CHARGER WORKING OR NOT! THEN IF IT IS WORKING MOVE TO DC JACK CONNECTOR OF YOUR LAPTOP... OR REMOVE FIRTS THEN BATTER FACT THEN CONNECT THE CHARGER THEN PUSH THE POWER BUTTON IF WORKING OR NOT
Jun 04, 2009 | Dell Latitude D600 Notebook
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
Keeps loosing battery/power
If it will not work on AC Adapter without battery in it, then you have a bad AC Adapter and the battery is fine. You don't have to get an expensive AC adapter from the original manufacturer. Just look on the bottom of the AC adapter and write down the Volts and Wattage. You can get another at a place like Lowe's or Home Depot. But you must make sure that the Voltage matches exactly, to much voltage and it will fry your computer, to little voltage and it will not run your computer.
Dec 23, 2008 | Toshiba Satellite 2455-S305 Notebook
Dell Latitude D505 Notebook Logo
14 people viewed this question
Alun Cox
