Question about Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
Heater will not shut off when tempature is reached
  • 43,501 Answers
The thermostat has gone bad.... replace the t-sta and it will work again correctly.
heatman101
Posted on Aug 20, 2010
I want to add coolant directly to radiator. too low to run engine and use resevoir for filler
Assuming you have no visible leeks I would add neat antifreeze for the correct frost protection you want then top up with water, run the engine with the heater on and allow the engine to reach running tempature before checking coolant level some systems have bleed screws in upper parts of hoses to vent air you may need to do this while the engine is coming to tempature or the water will not circulate fully if the heater puts out warm /hot air you know it has reached the metrix of the heater. Allow to cool before removing radiator cap and check level this can be done by squeezing the upper radiator hose and see the water move in resavoir, take care don't rush may need several bleeds.
Oct 03, 2017 | Cars & Trucks
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
It says if my ECO has tripped the water tempature has exceeded 200F. What would cause the tempature to reach 200F
Question posted under Rheem tank-type gas water heater.
Model number and gas valve are unknown.
Open following link to see typical ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Heater wont shut off when it gets to tempature. it just keeps running to 90 degrees.
See if the thermostat wires are pinched somewhere,becouse if the red and wight wires are touching it will call continuously,if there not touching somewhere you have a bad thermostat and need to replace it.
Jan 23, 2011 | Williams 3003622 Ceramic Wall Mounted...
Will the thermostat shown above that comes with the baseboard heaters shut off when the room reaches that tempature level?
it should,but you should be sure by setting to desired temp and take a temp reading with a digital thermometer as close to the bulb as possible
Feb 05, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
Heater blowing cold air, 4 babies really need heat....
Your heater core could be blocked. Check the hoses going to it on the inside of the engine compartment. There will be 2 5/8' heater hoses going into firewall adjacent to one another. The tempature of these hoses should be almost the same after your van has reached normal operating tempature and your temp select switch is on hot(heat). If not it's a good idication your heater core may have some blockage in it. You would then have to flush it out or replace it. Hope that helps.
Nov 03, 2009 | 2000 Dodge Grand Caravan
Heater slow coming back on after having reached temperature.
lower the tempature setting so the residual heat is the right temp your looking for
Jun 20, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater Logo
89 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
