Question about Frigidaire Dishwashers
The door wont stay shut on frigidaire 4300. I have cleaned all around including gasket. Halfway through the wash cycle, cycle stops and we get CL code for open door. If we push on door, it goes for another few minutes.
    Sergeant:
    Champion:
  • 311 Answers
Something is wrong with the door latch. Replace or make adjustment.
Posted on Aug 19, 2010
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
Jan 28, 2016 | Frigidaire Dishwashers
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Unit is giving me a flashing CL and won't start cleaning cycle. The door is closed.
When you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
Ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
If that did not fix the problem then the door switch has gone bad on you. You will need to replace the door switch.
If I can get the model # I will be more than happy to help you find one.
May 11, 2010 | Frigidaire 24 in. PLD2850 Built-in...
When I shut the left door the right door pops open, it is always open.... I need it to stay shut
put some heavy stuff on the door like soda or water bottles,also wash around the frame where the door gasket touches the fridge and wash the gasket too, there are magnets inside the gasket and if there's anything on the frame it could stop the gasket from making a good seal,how old is the fridge?what shape is the gasket in?if it's torn or lost it's shape it should be replaced.most likely you might just have to get some weight on the door to stop it from popping open
Mar 07, 2010 | Maytag MFD2561HE Bottom Freezer French...
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
Have frigidare pro series, model PLD256oLCC1 in stainless. stopped working. says "CL" on door front screen. what does this mean? how to fix?
my dishwasher is stuck on clean and when you shut the door it goes on. can't cancel wash or change wash
Jul 08, 2009 | Frigidaire Dishwashers
Frigidaire clothes washer model #FWT445GES1. The door wont stay shut, it pops open. The unit wont turn on even when I hold the door shut
I was having this problem. I thought the door catch was damaged but looked it up online and saw that it was intact. I was just about to call the repairman when I took another look and found that the rubber seal around the door was not properly seated. Duh! Almost cost me $100+ and lots of humiliation.
Jun 22, 2008 | Frigidaire Washing Machines
Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Mar 24, 2008 | Dishwashers
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Dishwashers Logo
123 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
