Question about Garden
I need throttle or brake cable sleeve that I can cut to length - the plastic tube or spiral wire that the operating cable slides through. I also need the end that can be crimped on as well. This way I can fabricate my own throttle cables.
  • linwoodsprou Aug 19, 2010
    On my way to the bike shop tomorrow :-)
  • 905 Answers
Local bike shops carry the cable and tube that you are referring to, and in bulk. You might try approaching them to see if you are able to buy x amount of feet, and have them show you how to crimp on the ends as well.
Posted on Aug 19, 2010
How do I replace the throttle grip on a 1998 harley davidson electra glide standard?
cut the old one off champhere the edge off the plastic sleeve then spray brake kleen in the new grip and slide it on
Apr 30, 2014 | 2005 Harley Davidson FXDXI Dyna Super...
2005 FLTRI, Front brake lever won't turn off brake light.
Loosen the front brake master cylinder clamping bolts and slide the entire assembly down towards the right handlebar switch housing as close as it will go. If the brake light does not go off then, the switch in the right handlebar switch housing is broken and must be replace.
To replace the switch, you must take the two bolts that hold the housing halves together out. Lift the upper half and loosen the throttle cable and idle cable. Remove the throttle sleeve and allow the lower half of switch housing to come away from the handlebar. The front brake light switch is the small switch in front of the housing. Unsolder the wires, replace the switch with a new one, and resolder the original wires to the new switch. Reassemble the throttle sleeve and switch housing, adjust the throttle cable and idle cable and check for proper operation.
Ride safe
Steve
Mar 24, 2011 | 2005 Harley Davidson FLTRI Road Glide
When using the front wheel brake the brake lihgt comes on and only goes off half way out. If released all the way out light stays on??????
I would guess that you have a bad front brake light switch. The switch in located in the right handlebar switch housing. To get to it, you'll have to loosen the adjusters on your throttle and idle cables. Then take out the two screws holding the switch housing halves together. Disconnect the throttle and idle cables from the throttle sleeve and carefully separate the two switch housing halves. The brake light switch is the small switch located in the front of the housing. You will have to de-solder the wires from the switch, replace the old switch with a new one by removing the screw that holds the switch in place, then re-solder the wires to the new switch.
Lubricate the handlebar and the inside of the throttle sleeve with some thin grease and install it back into the lower switch half. Reconnect the throttle and idle cables and carefully reassemble the two switch housing halves being very careful not to pinch any wires. Slide the throttle assemble all the way up against the front brake master cylinder. Readjust the two cables leaving just a bit of slack in each one. Turn the throttle wide open and let it go. The throttle should "snap" shut. If not, readjust the position of the throttle assembly on the handlebars and the cable adjustment until it does.
Good Luck
Steve
Feb 22, 2011 | 2000 Harley Davidson FXDL Dyna Low Rider
How do i remove the right side hand grip to replace with a new one?
The right side handgrip is the throttle sleeve assembly and grip combined. To get it out, first, adjust both the throttle cable and the idle cable (both cable going into the throttle assembly) to give you as much slack as possible. Loosen the two bolts that hold the front brake master cylinder on and move the master cylinder towards the center of the handlebars just a bit. The remvove the two bolts that hold the right handlebar switch housing together. Carefully move the top half away. There are a lot of wires in this housing and you don't want to break or pinch any of them.
Now, you can see the round part of the throttle sleeve and where the cables connect to it. Each of the cables has a ferrel on the ball on the end of the cable. Do not lose these ferrels. Work each of the cables with the ferrell out of it's hole in the throttle sleeve. Lower the bottom half of the switch housing and remove the throttle sleeve from the handlebar.
Now, before installing the new sleeve, lubricate the handlebar, the inside of the throttle sleeve, and the round part where the cables go with white lithium grease. Slide the throttle sleeve back up on the handlebar and reverse you disassembly procedure to get it back together. Be very careful not to pinch any of the wires when you reassemble the swith housing. Once you have the housing together but before you tighten it down, slide the throttle grip toward the center of the handlebars until it stops and then back it off about a half inch or so then reposition the front brake master cylinder as close to the right switch houseing as possible and tighten all screws.
Adjust the throttle cable and the idle cable so that they each have just a bit of slack in them. Twist the throttle grip to the wide open throttle position (engine off of course) and let it go. The throttle should snap back to the idle position. If it doesn't, work with the throttle until it does.
Failure to insure the proper throttle operation could lead to a loss of control of the machine resulting in serious injury or death. This job MUST be done correctly.
Good Luck
steve
Sep 12, 2010 | Harley Davidson FXSTD Softail Duece...
I need to remove the rt.handlebar throttle grip and replace it. need some pictures.
If you want pictures, I'm afraid that you'll have to purchase a manual somewhere. This forum will only allow me to send a picture of 150Kb size. Replacing the throttle grips is not difficult.
First, loosen the locknuts on the throttle and idle cables at the twist grip. Adjust the adjuster barrel inwards all the way getting as much slack as possible. Now, loosen the bolts holding the front master cylinder onto the handlebars and slide it towards the center of the bars just a bit. Remove the two bolts that hold the right handlebar switch housing together. Carefully lift the top portion of the switch housing and move it towards the front of the bike exposing the throttle twist grip. Work each of the cables out of the nylon wheel of the twist grip. Do not loose the barrels that go on the ends of each cable. Once you have the cables loose from the wheel, lower the lower switch housing and remove the right grip from the handlebar.
Now, take the new grip and apply a coating of white lithium grease to the wheel part and the inside of the throttle sleeve in the grip. Put a coating of grease on the handlebar end where the sleeve rides as well. Slide the throttle sleeve and grip onto the handlebars. Bring the lower switch half up and reconnect the cables to the throttle wheel. Carefully reposition the top half to the switch housing and make sure that no wires are being pinched. Install the two bolts but don't tighten. Slide the throttle grip all the way up on the handlebars and then back off about a 1/4" or so. Tighten the two bolts. Now, adjust the two cables to where they each have just a bit of slack. Turn the throttle grip to the wide open position and release it. The throttle should snap shut. If not, work with it until you get it to where it does. Once operating properly, reposition the front brake master cylinder.
Make sure your throttle operates properly. An improperly operating throttle control can cause lose of control of the bike resulting in serious injury or death.
Good Luck
Steve
Sep 06, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
How do you replace the starter switch on 2006 Sportster 883
To replace the starter switch on your bike, you must disassemble the right hand swith assembly on your bike. Start by loosening the throttle cables. Loosen the locknut and turn the adjuster to make the cables as loose as possible. Now. remove the two bolts that hold the switch housing together and seperate the two halves. Work the throttle cables out of the throttle sleeve being careful not to lose the barrels that go on the end of the cables. Slide the throttle sleeve down and out of the way.
With the switch housing away from the handlebars, you can now remove the screw that holds the starter switch and "Run/Stop" switch in the housing. Best as I can remember, they come as pair. The new switches come with the wires on them but you can't fish them down the wire sheath very easily. We used to cut the wires from the old switch and solder them to the new switches so the job looked like it came from the factory. The rest is simply the reverse of the disassembly.
Be very careful with the throttle assembly. Use white lithium grease to lubricate the inside of the throttle sleeve, the handlebar, and the nylon disc where the cables connect. Put the barrel ferrels on the end of the cables and work them into the holes in the nylon disc. Bolt the switch housings together with the throttle sleeve inside. Adjust the throttle cables so that there is a little slack in each one. Do not adjust them tight or the throttle will stick. With the engine off, twist the throttle wide open and let go. It should snap back to idle position. If not, work with it until it does. Failure to ensure proper throttle operation can cause serious injury or death. Do this job correctly.
Good Luck
steve
Aug 15, 2010 | 2005 Harley Davidson XL 883C Sportster...
BRAKE LIGHT STAYS
Usually, if a brake light is staying on, it's because of the front brake light switch. The switch is located in the right handlebar switch housing and is operated by a tang on the backside of the brake lever. Try loosening the bolts that hold the front brake master cylinder on the handlebars and slide the master cylinder out on the bars so that it is as close to the right handlebar switch housing as possible. If this doesn't extinguish the brake light, the switch is probably bad and needs replacing.
To replace the switch, you'll have to take the switch housing apart. Loosen the throttle cables and remove the two screws that hold the switch housing together. Take the cables out of the throttle sleeve and get the switch housing away from the handlebars. Remove the small screw that holds the switch into the housing. The earlier models had the switch soldered in. Not sure about the later models but you'll have to either solder the wires for the new switch or plug them on. Reassemble the housing in the opposite order. Be careful when you adjust the throttle cables. The throttle must operate properly, smoothly, and snap shut when you release the throtttle. If the throttle does not operate properly it could result in serious injury or death. Make sure that throttle works right.
Good Luck
Steve
Aug 11, 2010 | 2005 Harley Davidson FXSTD - FXSTDI...
I need too change right side grip on my 2005 heritage softtail any diagram thax,s
I'm sorry but I can't send a diagram via this site. I have no idea where I can get a diagram either.
But, to replace the throttle grip on your Softail, you'll see the not only are you replacing but you're replacing the throttle sleeve as well. This actually makes it easier.
To replace the grip, first loosen the throttle and idle cables as loose as you can at the adjusters close to the throttle grip. Then remove the screws that hold the two halves of the throttle switch housings together. Carefully seperate the housing halves as much as the wires will allow.
You'll see the cables coming up and connecting to the throttle sleeve. Each cable will have a ball and a ferrell on it. Work both cables loose and slide the throttle sleeve off the handlebar.
Now, lubricate the inside of the new throttle sleeve, the cable area of the throttle sleeve and the handlebar with fresh white lithium grease. Slide the throttle sleeve up on the handlebar and work the cables back into the throttle sleeve. Be careful not to lose the ferrells. They must be in there for the throttle to work properly.
Once you get the cables installed into the sleeve, put the switch housings together and install the bolts. Before tighten the bolts slide the throttle up onto the handlebar until it stops. Then back if off about 1/8 to 1/4" or so. Tighten the bolts. Readjust the cables leaving just a bit of slack in the throttle cable.
With the engine off, twist the throttle to wide open throttle and let go of the throttle grip. The throttle should snap shut. If not, loosen the cables a bit or back the throttle grip a bit further off the handlebars. The throttle grip must work correctly or serious injury or death may result. This job must be done correctly. It's not difficult just make sure it's right.
Good luck
Steve
Aug 04, 2010 | Harley Davidson FLSTC Heritage Softail...
Need to chnage the handlebar grips on my 2006 wide glide
The left side grip just slips onto the handlebars. There may be some glue to help hold it on. I usually take a very small bladed screwdriver and slide it between the handlebar and the grip and spray some WD40 or something in there. You may have to loosen the bolts that hold the switch housing on and move it inward to the center of the handlebars just a bit to get the screwdriver under the grip.
On the right hand side, things are a bit different. The handlebar grip is on a plastic tube that operates the throttle cables. To get it off, you must loosen both of the cables at the adjusters. Then, take the bolts out that hold the top and bottom halves of the switch housing together. Seperate the switch housing so that you can get to the cables in the housing. Carefully, remove the cables and the ferrells from the twist grip and remove it.
Lubricate the new throttle sleeve with white lithium grease and slide in onto the handlebars. Reinstall the throttle and idle cables with their ferrells in the appropiate slots. Reassemble the switch housing and readjust the throttle and idle cables. Check for proper operation prior to starting the engine.
Good Luck
Steve
May 09, 2010 | 2006 Harley Davidson FXDWGI Dyna Wide...
I have an RSVP stainless steel knock box and need to replace the rubber sleeve and grommets on the bar. Where can I buy these. The shop where I purchased the box does not stock them. Thanks Al
Hi Al:
Ok, here's what the pros do.
Sleeve-- get a 1-2 foot length of reinforced rubber tubing/hose. Measure the diameter of the inner bar, get the right Inside Diameter on the tubing, cut the right length and slip over the bar-- if the fit is tight, you may need a drop of dish soap to slide it. Lasts for years, much better than the old sleeve.
Grommets. Look at an auto supply store for auto wiring grommets. http://www.autowiringsolutions.com/search.php is a good place to start. Buy a dozen of 'em, and replace them when they split :-)
Nov 29, 2009 | RSVP Espresso Knock Box with Tamp Station...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
