I have an error code F01 and F02 on an Indesit WIE 167, can you tell me what the cause and solution is?
5 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: Indesit WIE 1375 error code?
This is a pressure switch error.
It still thinks the machine is empty because the switch sees no pressure (simple dip tube).
But this may be as simple as a vent hose come off.
To check,
First isolate supply, then remove screws at top rear of the machine.
Slide the lid rearwards, and remove.
The small hoses should go to the drawer area, and the pressure switch will sit at the end of one of them.
If there are any rips or damage to a hose it need replacing.
Check all hoses are where they should be.
If this doesn't work, please ask here again so I can troubleshoot further.
Thanks for using Fixya!
Posted on Jun 22, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Indesit WIE 167 says "test".
There is a fault on the program board. It more than likely needs a replacement.
Posted on Nov 05, 2008
blueextc3221
  • 15935 Answers
SOURCE: indesit washing macine displaying error code F-11
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Chesc
  • 59 Answers
SOURCE: My Indesit Washing Machine (Model
F09 - Setup error
Book a washing machine repair
Posted on May 24, 2011
F-03
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Jun 21, 2011 | Indesit W 123 Front Load Washer
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Oct 07, 2009 | Washing Machines
Bearings on a indest wie 167 washing machine
You can download a user manual for your m/c, but not a repair manual, Go to>
www.indesit .co.uk
Follow the links. To remove the spider, remove the rear panel, remove drum belt, undo drum pulley, you may have to heat the screw holding the pulley,undo all screws that you can see holding the spider to drum rear.
Withdraw spider, you may have to use some force to pull it off.
Fit new bearings or spider, and reassemble..
plz rate this solution.
Dec 15, 2008 | Indesit WA 115 Front Load Washer
Indesit W1XE127 showing default display F-01 after 7 minutes of operation. What's the problem?
Hi.
Error code F01 normally indicates a faultry motor triac.
Unfortunately you are going to have to call an engineer.
Please leave feedback.
Thanks.
Nov 27, 2008 | Indesit Washing Machines
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Error F01 and F02
Both of these error codes are related to the reels inside of the camcorder. The error codes that you mention stand for No Take Up Reel Rotation (F01) and No Supply Reel Rotation (F02). The take up reel is the one that pulls in the extra slack while the tape is running so that the tape itself does not become loose and choppy. The supply reel is the reel in charge of turning to allow the tape to unwind. What you are experiencing are both common reel rotation errors.
First things first, restore your camcorder to factory settings, take out the battery and leave it out over night, plug it back in the next morning. If that doesn't fix it, try a completely different tape that you've used in the camcorder before to see if there is something wrong with the tape reels (sometimes they are loose) or the tape itself.
If that does not work, your next step is cleaning the camcorder. Use a cleaning tape. You may want to perform two or three cleanings in order to make sure that the camcorder is back to normal. You can also use an electronics dusting brush and manually clean out any visible dirt or dust, sometimes blowing cool air (such as the canned air used to clean computer keyboards) directly into the camera can fix the problem as well.
Unfortunately, if neither of these solutions fixes it, it's time to take it to a repair shop, it may need a new reel mechanism inside of the camcorder.
Mar 30, 2017 | Panasonic PV-DV710 Camcorder
Washing Machines Logo
273 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
