Question about Recoton Advent Advent Q2035A 20" TV
Where can I purchase replacement ear pads for my Advent AW770 wireless headphones?
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Where do i get a manual for the Audiovox Advent AW770 Wireless Headphones?
I found the manual linked on the Amazon Product Page for the headsets. You can download it here:
http://www.amazon.com/Audiovox-Advent-Wireless-Headphones-Silver/dp/B00000J1GA
May 05, 2011 | Audiovox Audio Players & Recorders
Need replacement ear pads for TV777
See my tip on headphones. Just click my user name to find it. Go to the bottom of the tip there ia a link to a firm that might have them.
Feb 16, 2011 | Bebe Sounds BEBE-TV777 Wireless Headphones
Where do I find replacement cushion ear pads for a Recoton W500 wireless stereo headphone system? The outer layer as deteriorated to the point of being unusable for the fine, black debris that comes off:...
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
Feb 15, 2011 | Audio Players & Recorders
Need ear cushions for HP-CN5 headphones. Where can I get them?
One of our people answered this question in Oct 2009.
It appears Radio Shack still has them, Catalog #330-0288 - Replacement Headphone Earpads
They can be purchased online here
www.radioshack.com/product/index.jsp?productId=3786220#330-0288
If you can't get them from found some you can look at that are claimed to fit Aiwa on eBay.
90mm-OVAL-Headphone-ear-pads - Measure yours, read their information
Feb 02, 2011 | Aiwa HP-CN5 Headphones
Where can I purchase replacement ear pads for the sony mdr-if5000 headphone. Thanks.
If you click my name it will take you to a tip of mine on headphones. At the bottom of it is a link that will help you solve your problem.
Nov 17, 2010 | Sony MDR-IF5000 Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
Mar 19, 2009 | JVC Gumy Ear Bud Headphone - Peppermint...
Need instructions for replacement of headband and ear cushions.
It should be easy - I just eased mine out by pulling on the top and bottom parts of the headphone cushion/pad.
Hope that helps
Mar 27, 2008 | Sennheiser HD 600 Consumer Headphones
Recoton Advent Advent Q2035A 20" TV Logo
645 people viewed this question
Top Recoton Advent Televison & Video Experts
Rommel Balcita
Jaime Hernandez
oodio
oodio
Level 1 Expert
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
