Question about Panasonic DMR-EZ47V DVD Recorder/VCR
What error code is f 60? is it repairable? - Panasonic DMR-EZ47V DVD Recorder/VCR
  • 2,200 Answers
F60 error is associated with a failure of one of the main circuit boards inside the unit.
Unfortunately it may not be economic to repair unless you could source a failed unit of Ebay and are confident in electronics work.
One thing you should try is a factory reset which although unlikely to resolve the error will do no harm and there is always an offchance that it will help.
To do this;
1) Flip down the front panel to reveal the channel buttons at the front of the unit itself.
2) With the recorder on press and hold the channel up and down buttons at the same time until it says "Bye" on the display.
3) Wait 10 seconds before powering up and try the unit to see if it has helped.
Please do leave a vote for the solution. Thanks.
Posted on Aug 19, 2010
7 led blinks. Which board do I need to repair?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
May 27, 2015 | Panasonic VIERA TC-P60ST60 60" 3D Plasma...
Tip
Whirlpool Calypso Dryer Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
  • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
  • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
  • 60 degrees F. - 15.3K ohms.
  • 70 degrees F. - 11.9K ohms.
  • 80 degrees F. - 9.2K ohms.
E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
  • This error code is displayed only in diagnostics mode.
on Jul 19, 2010 | Washing Machines
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure Solution : Power the Machine Off and On CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
  1. Press the power switch to the [O] (off) position.
    NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
  2. Wait 60 seconds, and then press the power switch to the ['] (on) position.
Jun 26, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
It will not finish the spin cycle. It shows a code. N i dont know what the code means.
Error code dc or UC is an unbalance code for FAV6800A or FAV9800A. Is that the error code to the LED display if the machine model is the FAV6800A?
If so do you want to DIY the fix or call in a repair service.
In most cases the repair service may not have a clue and you end up throwing $60 or so down the drain on a usless service call.
See this post it helped someone recently
http://www.fixya.com/support/t8054642-machine_flashes_dc_twelve_minutes_go
Follow the links if you want to save your $1K machine.
Jan 30, 2011 | Maytag Neptune FAV6800AW Top Load Washer
LE error code, bell ringing
Not an expert, but we paid $60 for the repair man to come out and just run his hand along the touch pad on the door. It stopped the error code and the bell ringing noise! I wish they would have mentioned that over the phone and I could have saved $60!
Nov 10, 2010 | LG LDF6810ST Stainless Steel Built-in...
7 years old wont switch off programme seems stuck
Disconnect power at the mains power or breaker. Leave it switched off for 60 minutes then turn it back on to see if the error has cleared or reappears. If it reappears then note any error code or flashing lights and call in a repair man.
Nov 08, 2009 | Siemens Dishwashers
Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
Dec 15, 2008 | Pentax MZ-60 QD 35mm SLR Camera
I cannot load the film into my pentax mz 60 it keeps showing the error message. I have no trouble loading the film into my second camera (same)
rootseya,
pentax error codes are in the repair manual for camera repair technicians. the camera needs repaired.take or send your camera to a camera repair shop for an estimate.
Xbox error
check this out
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Aug 19, 2008 | Microsoft Xbox 360 Console
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
1,381 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
