Question about Sony Playstation 3 (PS3) Console
Plaged my playstaion 3 into a none hd tv with all the correct leads but i am not getting any sound or picture
    President:
  • 1,139 Answers
Ok please follow these steps to get your PS3 working again :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. The console will beep as soon as you press it and then beep again about 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for your PS3 to start up
This procedure basically resets the video output back to standard definition and you should then be able to setup the video correctly using the PS3 menu
Hope this helps and thank you for using FixYa
Posted on Aug 19, 2010
I cannot get a picture from my sc-bt100 on my screen the sound is working no problem checked all leads and connections
How are you hooking it up? To what kind of TV? Best connection for SC-BT100 is via HDMI out on SC-BT100 to HDMI in on TV, otherwise you aren't getting full HD output. Make sure your TV is set to correct input source.....
Dec 27, 2009 | Panasonic SC-BT100 Theater System
No sound threw hd
hey jason,
umm im just throwing suggestions out there, have you tried the sound in all of the sound ports in your tv? and if you already have all i can say is try putting the xbox 360 on another tv to see if your cables are good, if not im guessing its your tv. If you have a newer xbox 360 with a hdmi port just get one of those cables they work great as well.
May 15, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Connection to the tv
are the cable connected to the correct colour, and did you select the right output for video? (the switch leading to thexbox360) if you are you using hd (all the cable) switchhd hd, if not switch to the other one and use only the yellow cable.
Apr 10, 2009 | Microsoft Xbox 360 Console
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
No picture or sound on ordinary TV after hooking up with HD TV
You system is still out-putting through the HDMI cable. Press & hold the "on" button after the system is already on, it should go back to regular factory settings & show up on your screen.
Dec 14, 2008 | Sony Playstation 3 (PS3) Console
I am trying to hook up my xbox 360 to a Magnavox 56" big screen. I plugged in the cords (red, white, yellow) all where they are supposed to be but all I am getting is sound and no picture. Yesterday we had...
If you have HD T.V then make sure you have the settings correct on your console and leads for HD. Also check that the leads are pushed in firmly on both the TV and the console
Nov 27, 2008 | Philips Magnavox 20MS233S 20" TV
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Hi def
add a scart connection , and use this to check that the hdmi setup is correct using the system settings option
Aug 09, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
