Question about Jet Equipment Chain Hoist 1TON 10 Ft Lift #111000
Manual chain hoist keeps slipping load chain when under load (lifting and lowering). It will hold when you keep tension on the slack side of load chain. Any ideas?
  • 2,760 Answers
Sounds if the motor brake is not holding , this is a wear part and will require adjustment/replacement over its life time , the brake is located under the motor cover , but if your not sure what to adjust ,then im gonna suggest for safetys of you and the people around it' s sake you get a profesional to service this hoist
Posted on Feb 10, 2015
How hard is it to change cam chain an a 1995 Honda cb 750 I have a new chain and a link, and yes you can buy a link And do it engine in sit, just want a heads up on how best to go about it.
obviously some people dont read the questions before they answer but my first question would be why are you wanting to replace the cam chain but that aside heres a reasonable tip for most of japenese overhead cam fourstrokes.......if you do in fact have a " master link" then remove your valve cover and magneto cover and get your timing marks lined up.Take a picture or make some marks with a sharpie or whatever you need to have a reference point for timing marks. Take 2 pieces of flexible coated wire like some heavy guage speaker wire and cut off prob 5 feet or so twice. Take one piece and loop it around the last roller in front of your link your removing and do the same to the other side. with those two tied off loosely to your frame from above remove your link. So the front side should be suspending the front half of the chain to the frame above and the rear side of the separated chain should be suspended by the other wire. Now join your new chain to the old chain hanging off the front side with your master link. remove all tension from your cam chain tensioner then your ready to do some threading. Lay your new chain off the front of the motor hanging down somewhere it wont be collecting debris. this is where you need an assistant. Have your friend hold the new chain up and off to the front and keep sufficient pressure so slack wont fall inside the motor and jam up then take the back side wire and start slowly with your right hand lifting the backside of the old chain out as your turning your magneto counterclockwise with your left hand. Make sure you and your friend keep sufficient pressure on the chain ends to keep the chain contacting the bottom sprocket. So the rear chain holder is actually pulling the old chain out and turning the whole rotating assembly with the magneto in a delicate dance till the new chain is up out of the rear casing and the friends chain is ready to get sucked into the front end. If its a dual overhead motor then drape the front slack over the front cam sprocket and have friend hold their hand ontop while the rear segment holder removes the old chain then drapes the end of the new chain over the rear sprocket then replace masterlink which should be acheivable if your cam chain tensioner was allthe way out Now reapply chain tension with tensioner and re verify all timing marks. any adjustments can be made right there between cams to line up everything. Buy your friend a 6 pack of suds and and go for a nice ride tomorrow after you and your friend have slept off the celebration 6 packs from last night. good luck
Feb 02, 2015 | 1995 Honda CB 750 Nighthawk
How do i get the chain back on the bar???
It depends on how it came off. Was it way too loose? Undo the two nuts holding the bar to the motor, slip the bar off the tapered tang that is part of the chain tensioner, put the chain on the bar and around the drive sprocket/gear. You may have to loosen the tensioner screw located on one side of the bar to have enough slack to get the chain on correctly. Reinstall the bar and holding nuts (loosely at first) and adjust the chain tensioner screw so that the chain is tight enough that can pull up on the links in the center of the bar but not loose enough so that the links come comepletely out of the bar slot.
Sep 01, 2013 | Husqvarna Garden
How much slack should be in the chain
If you tug on the chain in the middle of the guide, the guide teeth should come out of the guide bar groove with a gap of about 1 - 2 mm (about 1/16 inch). This is from the Ryobi Users Instruction Sheet, please rate this response.
May 21, 2011 | Ryobi Factory Reconditioned 18" 40cc...
How do i replace my serpentine belt on my 1998 chevy cavalier 2.4
I have a 2.4 also. The secret is to use a ratcheting box wrench on the tensioner pulley. thread the belt onto all of the pulleys except the tensioner. Then slip the ratcheting box between the fender wall and the face of the pulley. (keep the belt on the engine side of the wrentch) then pull up on the tensioner as far as space will permit. wedge something under the tensioner to hold it where it is. ratchet back down on the wrench and pull up again. this should lift the tensioner up high enough to slip the belt into place.
Apr 28, 2011 | 1998 Chevrolet Cavalier
When i flush the toliet the flapper stays up and will not fall back down so toliet keeps trying to fill
adjust the chain that connects the flap to the handle give it some slack but not so much as to get chain laying under the flap good luck and hope it helps
Nov 09, 2010 | American Standard Home
How to replace the chain?
Look on the side of the saw, where the blade/chain enter the plastic case. You will see a nut in there. Loosen the nut, then push the bar backwards towards the saw. It will put slack in the chain and you can pull it off the sprocket/clutch in there. (Use a screwdriver if you can't reach in there with your fingers) and wear gloves... even a dull chain can gouge you if your fingers slip. Once it's off the sprocket, then just pull the whole chain off. To install the new one, put it around the sprocket, make sure the chain guides are lined up with the groove in the bar and on the tip of the bar, then pull out on the bar (away from saw) to take the slack out of the chain. Holding the bar firmly to keep the tension on the chain, tighten the nut again. Bada-bing you're done. Should only take about 5 minutes to change it.
Jun 28, 2010 | Remington Electric Chain Saw
Describe your steps on how to take apart a nissan engine
If in the car, remove the exhaust pipe at the flange. Remove the valve copver. Insert a wood wedce between the timeing chane and tensioner. Remove the can shaft gear. Mark it with a punch to the chain. Unloosen the head bolts. the whole hed with the intake and exhaust manafold should lift out. If the lower block needs to be removed, remove all belts and hardware. undo the transmission bolts and starter. Remove the moter mounts. Use a sshort chain and bolt it to the engine body front and back. Use a small hoist to lift it out. Support the transmission and remove the radiator and A/C coil. Give it a shot, Keep track of the order things are taken apart. Mark all wires and vacuum lines.
Jan 17, 2010 | 1992 Nissan 240SX Fastback
How do I tighten chain on Model Poulan 2050. Can't seem to get tight enough.
Hold the nose up!
c581361.gif Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Nov 18, 2009 | Poulan Garden
Thread won't stay in discs and under tension spring
On the first set of spring loaded tensioner plates there is a small bar that comes out straight at you. Bring the thread over this bar before heading down to the next catch. Also make sure you do not have dirt in between the plates. The only other possibility is the tension release is easing the thread tension while sewing. (like your knee hits the foot lift or the whole foot lift is too tightly assembled
good luck
May 21, 2008 | Consew 206RB
Jet Equipment Chain Hoist 1TON 10 Ft Lift #111000 Logo
188 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
